What methanol nozzle size?
Old 01-20-2010, 10:48 AM
  #151
devilsown's Avatar
5gph may not be enough but its certain better to start off to small than go to big. We are talking about peoples motors here. So i always try to give safe knowledgeable advice. If your too small you will still get some of the cooling benefits of the water/meth. Without risk of engine damage.
If you go to big your going to have to remove fuel to make it run right. This is not always a safe tuning practice.
It takes trial and error to come up with the proper nozzle size.
As for a cool tank, these should be out very shortly.
http://www.alcohol-injection.com/2-5...-tank-346.html
Features a real sump,
internal baffle for fluid control under braking
Same material and construction as fuel cells
Proper cooling for the pump.
Old 01-20-2010, 11:20 AM
  #152
Rent me! per hour
Area47's Avatar
Originally Posted by Bika
Rodney is right. 5 isnt enough.
the 5 is more than enough.
Old 01-20-2010, 11:10 PM
  #153
Fail Less.
Bika's Avatar
for 340whp? I would have thought 7gph for a 2.9" or smaller pullied tvs.
My bad, I guess.
Old 01-21-2010, 09:25 AM
  #154
harryresh's Avatar
would running a 90/10 be a good mix?
Old 01-21-2010, 09:39 AM
  #155
383_Stroker's Avatar
i'm running a 50/50 mix (in the summer) on a 5gph nozzle.. 25* of timing.. 3.1" on TVS
Works well
Old 01-24-2010, 08:08 AM
  #156
harryresh's Avatar
im running a 2.7 so i figure ill run a little more meth into the equation maybe a 75% mixture
Old 08-08-2012, 08:46 PM
  #157
ThexGovenor's Avatar
Sorry to bring a thread back from the dead, but its been a while since this was updated. Has any of the newer dynos and research shed any more light on the nozzle size situation when dealing with pump gas?
Smc252 (12-19-2021)
Old 08-10-2012, 04:53 PM
  #158
bratboy90's Avatar
Or just go E85 FTMFW
Smc252 (12-19-2021)
01-12-2016 12:01 AM
10-13-2015 09:32 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: What methanol nozzle size?
