All Cars Café The landing pad for automotive discussions, news, articles, and opinions. A place for the community to kick back and chat about all cars.
My Z31 300ZX build
Old 04-07-2015 | 12:03 AM
  #176
andrewcarr1993's Avatar
So you've only experienced about 3 PSI so far and it's coming back out. Sorry to hear.
Old 04-07-2015 | 01:07 AM
  #177
Sharkey's Avatar
how long did it run with no oil pressure?
Old 04-07-2015 | 01:18 AM
  #178
OzzyruleZ's Avatar
Probably a good 15 seconds between 3-5k rpm
Old 04-07-2015 | 01:31 AM
  #179
OzzyruleZ's Avatar
The best I can tell from where the giant oil slick is, it broke shortly after I went full throttle in 2nd. I wound it up to about 60mph, so that would be 3-4 seconds, I shifted into 3rd and just let it engine brake (break haha!) down to about 45, then pushed the clutch in, which would be another 10 seconds or so.
When I pushed the clutch in it shut off. This is nothing new as I'm still working on fuel cut recovery in the tune. I started it back up and it was clattering pretty bad and that is when I looked at the oil pressure gauge, seen it was 0 and killed the ignition. Honestly didn't hear anything before then, the car is stupid loud from rattling, creaking, wind noise, on top of turbo noises.
Old 04-07-2015 | 02:21 AM
  #180
Sharkey's Avatar
my porsche did the same thing, kinda. pushed the oil filter seal out half way through 2nd gear. judging by how long i saw the fireball, it took about 5 seconds to empty the oil pan. i let it coast as far as i could, fired it back up, drove it off the freeway and shut it off. end result is i fixed the oil filter and topped it up, oil pressure was fine and no noises.
if i were you, id pull the oil pan off in the car. pull the rod caps off one at a time, use a small screwdriver and roll the upper rod bearing out and have a look at it. i doubt its done any real damage, however in a boosted engine i wouldnt take a chance with the rod bearings. if you can get the pan off in the car id just do it this way, no reason to tear the motor out and all apart, id doubt there would be any damage. the clattering you heard would be valvetrain, with no oil pressures and lash adjusters will bleed down and your hearing the rocker hitting the tip of the valve.
Old 04-07-2015 | 11:59 AM
  #181
OzzyruleZ's Avatar
It is easier to pull the engine out and do it on an engine stand honestly. It is next to impossible to get the pan off with the turbo on and getting the turbo off in the car is beyond a nightmare.
It is very possible nothing is damaged. I started prepping to pull it this morning. I reached down and felt the turbine, it still spins beautifully and has no play. I would just rather spend the 100 dollars on bearings and the weekend making sure my $5K+ build is safe lol.
Old 04-11-2015 | 12:45 PM
  #182
OzzyruleZ's Avatar
Got the engine out and bottom end opened up this morning. Damage isn't as bad as I was expecting. Main bearings are scuffed up, the rod bearings took the brunt of the damage. One was loose in the journal like it was about to spin. Going to mic the crank just to be certain it is ok, clean the bottom end out and then put her back together.
Old 04-11-2015 | 02:04 PM
  #183
InfraRedline's Avatar
You definitely don't waste any time, as I've observed before.
Old 04-11-2015 | 02:42 PM
  #184
OzzyruleZ's Avatar
Sometimes I slack but I'm ready to start making some power lol
Old 04-11-2015 | 10:48 PM
  #185
Sharkey's Avatar
looks like you got it shut down just in time. a couple of those are looking pretty hot. just make sure no bearing material transfered to the crank or itll tear the new bearings out of it.
Old 04-12-2015 | 04:48 PM
  #186
OzzyruleZ's Avatar
Yeah, we'll be cleaning it all up.
Speaking of cleaning it all up... everything from the cross member to the differential is oil soaked. I bought some oven cleaner to hose it all down with, hopefully that cuts the stuff
Old 04-13-2015 | 02:17 PM
  #187
jonathan923's Avatar
am ready to see this car make some power too lol. good luck with the rebuild man!
Old 04-13-2015 | 08:01 PM
  #188
OzzyruleZ's Avatar
Thank you sir! Not sure I'll get it back together this week. Weather looks like crap all week long.
The weekend before my timing belt tensioner failed I was able to do a few runs with my friend in his supercharged z24. On 6psi with my gimped tune I was able to pull on him. Doesn't sound like much but that little car gives my 350z a hell of a run. So that tells me at the current settings it's making around 260whp. At 6psi the turbo isn't even near its efficiency range. It should get interesting when I start throwing boost to it.
Old 04-17-2015 | 01:22 PM
  #189
OzzyruleZ's Avatar
Ah the memories, seems like only yesterday I used ugly green to distract from the giant turbo and other mods in the engine bay. I have to say I do like the current iteration better!
Old 04-18-2015 | 10:57 AM
  #190
That's definitely a huge improvement! Looks so good under the hood.
Old 04-18-2015 | 12:45 PM
  #191
OzzyruleZ's Avatar
yeah it is amazing what some paint and a little attention to detail will do lol. First time around I was going for function over form, the upside was nobody expected it to be fast. This time around I figured if I'm spending this much money I might as well make it look nice.
Good news today, crank is ok, new bearings are in. Haven't buttoned it up yet though. I had a few things to do to the 350Z to prep it for the Tail of the Dragon. After that I was done. It is stupid humid and hot out so I was like to hell with this mess I'm going back inside
Old 05-02-2015 | 05:12 PM
  #192
SR Tech's Avatar
Update?
Old 05-03-2015 | 06:24 PM
  #193
OzzyruleZ's Avatar
I just got it running about an hour ago. Let it idle for about 30 minutes. Everything sounds good. I'm worried I may have shimmed the oil pump bypass to much lol. I'll find out tomorrow when I finish buttoning it up and take it for a ride. Hopefully I don't have to pull the engine again
While it was out I fixed an exhaust leak I had at the v band on the downpipe. I also went ahead and threw 14.5psi worth of spring in the wastegate. I'll likely see 15-16 at the manifold. She should pick up a good deal of power I can't wait to get that dialed in and see how she feels.
Old 05-09-2015 | 05:30 PM
  #194
OzzyruleZ's Avatar
Took the car to its first Cars and Coffee since the VG33 Megasquirt build. She ran great with exception of the lost sync in boost I'm battling. I picked up my friend John who is a pretty avid J-body tuner. He was impressed with how well the car ran and drove, he gave me an atta boy. He doesn't give those out very often lol. I parked right next to a black Cobalt SS, which one of you ******* was it??
Old 05-15-2015 | 03:19 PM
  #195
Sounds like it's going good, can you hit boost no issues yet or still lots of tuning to do?
Old 05-15-2015 | 03:24 PM
  #196
cool to see everything playing out ozzy! glad you seem to have gotten it put back together.
Old 05-15-2015 | 10:23 PM
  #197
OzzyruleZ's Avatar
Still lots of tuning. Prior to all the excitement with the thing trying to self destruct I was running 6 psi. It was running very well but super conservative. I have the spark advance at 10* in boost and low 11's high 10's AFR. Like that it out ran my friends supercharged LD9 Cavy. That car gives my 350z a good run. So I was pretty pleased with its performance with such conservative settings.
While I had the engine out I decided to bump the wastegate pressure up to 15psi. I've only gotten one decent pull before this lost sync thing started. It had tons of mid range, like it surprised me, but was kinda anemic up top but I figure that's due to how rich it is and the 10* advance. But now with this lost sync bs I can't go above 35-40% throttle or above 4k rpm without it acting up. Basically lost sync is it losing track of the crank and cam position sensor. So I've been trying to track it down.
Thank you sir. Still tons of bugs to work out and lots of tuning to do!
Old 05-19-2015 | 01:36 AM
  #198
OzzyruleZ's Avatar
I attempted to brake boost the car tonight on the way home. I wanted to see when the lost sync starts happening and also what IAT's look like in prolonged boost. All I managed to do was a giant rolling burnout. I was impressed.
Old 05-19-2015 | 02:25 AM
  #199
Sharkey's Avatar
what are you running for a crank trigger wheel? does it seem to be dependent on rpm, or on load? did it have any issues in the same operating range prior to pulling the engine back out to fix it?
if its load dependent (happening with the higher boost) all i can recommend is to make sure your crank and cam sensor wiring doesnt go anywhere near the coils. with the higher cylinder pressures there is more strain on the ignition system to ignite the mixture, and that can cause more emi, and its possible its interfering with the crank/cam sensors.
id start by checking over the wiring, check your sensor gaps, and make sure everything is tight. check your plug wires, make sure there are no nicks in them. also could try tightening up the plug gap.
Old 05-19-2015 | 12:02 PM
  #200
OzzyruleZ's Avatar
It is driving me nuts!
I'm using the stock distributor as it has the crank angle sensor built in with a DIYAutotune trigger wheel made specifically for it. I would say it is 90% dependent on load. I can get rpm up to 5-6k as long as I keep the throttle low. It however does it at idle sometimes as well as normal cruising but those are random. Sometimes it will not lose sync once in an hour drive cruising normal. Other times it will do it 10-15 times in a just a few minutes.
I've adjusted the potentiometers today from full CCW to full CW as DIYAutotune advised with no change in its behavior. So now I'm planning on pulling the harness this weekend to go over the solder joints and make sure nothing is damaged. I've already replaced the crank sensor and moved the harness around. The coils are on the strut towers so they are away from harness. The harness does pass over the drivers side plug wires but they are a good 3 inches below it.
Quick Reply: My Z31 300ZX build
