--||The Official Headlight and Taillight Thread||--
#303
All aftermarket projectors (that I know of) come with an adapter that plugs into the stock bulb connection/factory harness. This adapter just acts to split the appropriate wires to go to the low beam bulb and the high beam bulb.
#308
im thinkin about getting some headlights, im not a fan of the halos or the leds and all so...any opinions on these lights in black?
http://www.modernperformance.com/dep...lt-p-2096.html
OR THESE
http://www.ottperformance.com/store/...?idproduct=858
OR THESE
#309
OR THESE
OR THESE
#312
OR THESE
OR THESE
#314
come check ours out 10% off
http://www.jmautoracing.com/products...model=&engine=
Thanks guys and dont forget when you order use our promo code JMG010
AND THANKS AGAIN
James
AND THANKS AGAIN
James
#315
I just got mine from Modern. See the pics in my post today under *Vendor section* for Modern, or click on my Image Icon under my name to see the pics. The one pic with the lights off exaggerates the BLACK BACKGROUND on the lights, since it's dark and the flash highlighted the black. In day light it looks much more *natural*.
i think they will look good with my wheels when they finally show up. they are black with a polished lip...that reminds me, i gotta pm jasonaudio and see if he has an eta yet, i only ordered them BEFORE MEMORIAL DAY
Last edited by bobbyhill31286; 07-08-2010 at 07:55 PM. Reason: Automerged Doublepost
#316
I'm not sure if these exist, but are there any clear, monochrome, non-smoked, LED taillights? I think this would look alright on a black car..how is the 'smoke' coating applied? Or is it the plastic itself that is tinted?
#317
so i got my ebay led tails and i was looking at the wiring harnes inside the trunk and noticed on the driver side there is yellow brown and black. but on passanger there is blue black and brown. blue which is the turn signal. which is what i wanna splice into for the resistor. but my question is why is there yellow on the driver? do i only need one resistor for both the driver and passanger side? or do i splice into the yellow wire on the driver
i installed my stock inners and i didnt really like how it looked with the led outer.
so i bought ebay led tails and im going to get them profesionaly tinted bc with the ipcw you really cant leave the reverse hole untinted because the template on the light is bigger than the actual reverse hole and it would look weird because you would see red if you went by the template on the light for leaving untinted.
#318
Enjoy my smoked LED tails, the downside is the reverse lights don't seal properly, there is no lining on the bolt part like on the stock tail reverse lights, thus it doesn't seal properly, sealing it unconventionally with my brother.
#323
AND THANKS AGAIN
James
AND THANKS AGAIN
James
