--||The Official Headlight and Taillight Thread||--
#777
So I've gone through this whole thread and I was wondering if there was anyone that has made custom painted headlights that aren't black?? I'm working on a project but I want to see others that have headlights in different colors, can anyone help me out?
#778
https://www.cobaltss.net/forums/appe...thread-217768/
https://www.cobaltss.net/forums/pict...thread-239376/
https://www.cobaltss.net/forums/pict...lights-228605/
#779
just use the site search and put in "color matched headlights" you'll find them spread out in lots of different threads.
#780
#783
Anyone have any idea as to why the type 2 LED's will work for a while when the engine is cold, but after driving for it bit, they will then start acting like type 1 LED's? i bought the wrong resistors the first time, so now i have the 6OHM. Are the bulbs defective?
#785
Just save your money and make some retros. Will look and perform 100 times better. That's what I should have done in the first place. Cons for Gen 3's: Clear coat starts to fade after awhile, you'll need to do the anti glare mod for a better cutoff, and halos aren't bright, ccfls are way brighter. Pro's: You'll have halos and leds for looks, if you like that. Decent cutoff with proper aiming, and look better than stock chrome lights. After I got my retros I'll never go back to anything else. I love them! but if you don't have the money or want retros go with gen 3's or gen 4's. I've heard gen 4's have the best output though.
#786
#791
here is a couple of pics from my quad projector retrofit. got the idea from Padlock. was just gonna put in a set of FXrs at first but after seeing what he did i figured i could experiment a bit with my Gen 1 headlights. the plan is that the FXr will be my low beam and highbeam. The original projector has essentialy had the shroud trimmed back pretty radically it will be for highbeams only.
anyways PIC's
Lens off
Front Facia out and the bits removed. housing dremmeled out behind where the Gen 1 projector will go. The Fxr is going where the original projector went.
picture of inside the projector with the shroud trimmed back.
Teaser Pic of Gen 1 with the projector in the wrrong place.
i dont have the projector actually mounted yet. thats what its gonna look like though. just with a projector in the other spot as well.
anyways PIC's
Lens off
#797
is this a good deal?
http://www.ebay.com/itm/05-08-Chevy-Cobalt-Dual-Twin-CCFL-Halo-Ring-Projector-LED-Black-Headlights-Lamps/281104641652?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D7854305749200513205%26pid%3D100033%26prg%3D1011%26rk%3D4%26sd%3D140701110700%26
