disassemble Gen 1's?
Hey has anyone on here pulled the lenses off of gen 1 lights b4 ? just curious. i had a little run in today while blowing out condensation from the lights where my compressor (that hasn't been used in a while) blew in more water :'( now as the water dried i have water marks on the inside of the lenses... So want to pull the lights apart to A) Clean the lenses and B) get a better seal around the edge... should have taken everyone's advice about the bad seal in the first place ... live and learn...
Thanks i know you guys will have some helpful info... (yes i drained my compressor after this BS)
Ive taken apart stock lights and 3rd gens. You have to use heat to soften up the adhesive, you can use a heat gun or oven. start in one spot and work from there.
any specifics? i have done stockers and it sucked ... i really hope the gen 1's are easier... i just noticed they have screws holding the lens as well i dont want to mess them up is all ...
jcalvin1126
09-11-2015 10:24 AM
09BlkCrusader
09-09-2015 04:47 PM
