G5 GT - SS Rear lip interchangeable?
the only issue i see is that the G% uses and LS bumper with the lip attached and the SS uses the SS/NA bumper ( Different contour and lines, than an LS) with the Lip attached. im sure its doable,a nd not too much is needed, if anything.
i used my stock bumper and just cut the slits in it, when i bought my lip, royce made me buy the bumper too, so i was able to make a template of where ther slots should b, and i ordered the factory clips from gm< expensive little bastards
So I decided to do this today (even tho it was -6) the SS lip fits perfectly, however there are a few extra tabs on the SS lip that aren't cut out on the GT bumper. So either mark and cut the new holes or cut off the small tabs that the GT doesn't use. And the opening around the tailpipe needs to be trimmed bigger and across the bottom of the bumper needs to be trimmed.
But as for the lip itself fitting the contour and existing tab locations, its fits just fine.
#40
So glad I asked about this lol
If anyone has a VR GT lip to trade for my VR SS lip in the West Michigan, North IN or North IL area let me know! Otherwise ill just make a wanted ad come spring time...
#42
I don't know why there aren't more people on here with the SS with the G5GT rear end? It's so badass. Even cooler is the g5 gt rear end on a ss with the ss rear lip .... No Pontiac badge . I'm going to try and get that accomplished this winter..
#46
