Gestapo007's Paint Job Thread: Project Pumpkin
#1076
#1078
#1084
So ******* nice. Glad to see it almost there.
You gotta get some black HVAC/radio.
EDIT:
Didn't see you already talked about that. I'm planning on painting mine too opposed to swapping. I feel like you can't tape up the HVAC logos. If you did it would either take about a weeks time or look like **** in most cases. I'm gonna shop some on the computer and trace them onto vinyl then cut them out. Just like graphics on a car.
Is it your cam or does the drivers side need to be blocked and wheeled a bit? Looks like everyplace else is mirror like but that.
EDIT:
Last edited by JoshuaVnyrd1817; 05-05-2010 at 04:50 AM. Reason: Automerged Doublepost
#1085
#1086
EDIT:
EDIT:
#1092
HOLY **** I had a terrible day. Rained like a mother here last night, car is parked outside, go to get in it this morning and i turn the key and nothing happens. Nothing, lights go on, interior chimes are working fine, key turns and nothign even clicks on. Battery isnt dead, idk wtf it is. So i get out, take my mothers mustang to class, finish up a painting and refinishing final, come home, hope if there was water anywhere it dried out by now since its like 80* and sunny out today, try to start the car, nothing. It was just running last night! Check fuses and whatnot, everything looks perfect. DIsconnect battery, connect it again, disconnect ECU, connect it again. Switch ECU's. Nothing. Getting "Power Steering Failure, EBS OFF, Check ABS" flashing across my DIC.
Well i call roadside assistance and setup a service appointment. Install stock intake, remove my block off plate, take off charge pipes and BOV, connect the stock charge piping uptop, get the jack to connect it on the bottom, as im jacking up the car in the front on the engine cradle next to the motor mounts the jack SLIDES off the frame and crashes against my radiator. i quickly lower it and watch the fluid flow down onto the ground. ****!! I was so mad cursing outside throwing a fit. Get the stock piping on, call dealer to tell them i need a new radiator now, of course there on lunch and will call me back. Tow truck on the way, i get it all connected, then decide to remove my headlights and brackets and HID's so the dealer guys dont scratch the paint trying to remove all that when they remove the bumper to take radiator off. Well remove all that ****, tighten down the ground wire under the driver bracket, and decide ****, lets see if it starts now. It cranks right up. So im happy now, but then i see the coolant on the driveway and get sad again. So i cancel roadside assistance, call around to find a radiator. Still didnt find one yet but Autozone can get me one friday for 307. Dealer 379. Austins Tire is shopping around to see what they can find me. But now i have to replace my damn radiator. And buy a better jack since that **** is not happening again.
#1100
any1 wanna see pics?
I think the AC condensor is alright, i wont know untill i get the radiator, put it on, crank the car up and see if the AC blows cold. Its bent a bit but nowhere near as bad as the radiator.
And heres the culprit
