Hate to do this... hid problems..
searched around, saw some somewhat similar threads but different problems..
anywho, just got this Xentec HID kit off ebay...
Bi XENON 9003 H4 9007 H13 Dual High Low Beam HID KIT | eBay
u can kinda see the pics for how its set up on there...
anywho i installed it last night.
PROBLEM/S: The lights work. But, idk what causes it but sometimes when i switch them on they dont work. either one side, the other, or both. also, when this happens, i hear a noise coming from the the passenger side ballast. it especially turns off if i hit the highbeams
im sure i hooked them up right... the wires u need to connect to the stock harness are as follows:
new kit stock wires
blue red (drl)
black black (ground)
white orange (highbeam)
the kit came with basically a relay sort of ballast. the stock plug goes into it, and it kinda loops around to make it to the hid bulb evetually after a few hookups. no power or gorund wires needed.
anywho please help if u have dealt with this kit, anythings appreciated really, even trolls
new kit stock wires
blue red (drl)
also didn't know i'd need to remove the drl fuse... wouldn't that make the lights not work if i took that out?
thanks for ur help btw i appreciate it
did u ground the black wire or remove the drl fuse?
AWD > FWD
A real relay harness will almost guaranteed fix this, I've seen it plenty of times, the car cannot put out enough power to initially start up the bulb. Sometimes it can, sometimes it can't. A relay harness will ensure that they hid kit is getting enough power. I had this same issue in the past, and a relay harness was the fix
ftr, i actaully was reading on a somewhat similar thread about something like this last night that u were in
