Headlight Confusion
Headlight Confusion
Ok Im way confused now.
I was looking into geting projector headlights.
After reading about them Ive grown more and more
confused....
1: What is HID?
2: What is HALO?
I read the HIDs for Newbs and it didnt seem to awsner those questions.
it talks about doing Retrofits, and it says that HIDs are Illegal.
1: I do not want to cause someone to crash
2: I do not want to break the law
Ive heard that some of the Projector lights are crap,
But there are so many places/kinds to buy. People have said to get retros, because they are better. It seems that retros are takeing apart the stock lights and modifying the innards of them. I really dont want to do that. Id rather pull out the headligtht assembly and put in a diffrent one.
I hear there are diffrent generation ones..
So what are Gen1, vs Gen2, Vs Gen3, Vs Gen4 ect??
What im looking for is something that looks kinda cool, but more importantly, lights up the road better then stock so I can see better at night when I drive. My current stock headlights are somewhat crazing over.
One of the supporting vendors sells projector lights that look cool, but I cant find where it says if they are retors, or Gen1, 2 ect....
So whats the deal?
confused....
1: What is HID?
2: What is HALO?
So whats the deal?
the whole putting HIDs in headlights and making them illegal is when u stick them in the OEM housing. they dont have a proper cutoff shield so it ends up scattering light EVERYWHERE. im sure uve seen an oncoming car where ur like... holy fuckkkk light scatter and its realllly bright but it doesnt seem to light much of the road up
u dont have to worry about that with the projectors with the aftermarket ones cus they come with a cutoff shield and helps to stop scattering light. theres a trick with the gen 3s which make the cutoff shield even better and if you order from 3bspec they will mod it for you. it just requires u screwing a screw or something into somewhere.
HID is a type of bulb that requires a ballast to be powered and is a **** load brighter than halogens
halos are these
gens 3s have them as well as the earlier gens
everyone is rockin the gen 4's so if u want to be popular get those lol
halos are these
Ok I think I get it better then. Dont think HID is quite what I want then....
The projectors look cool, so is Halo = Projector ??
Some one posted a while ago that they had issues where the clear coat would get messed up and the leans crazes. Is that because of brand?
How do you tell what Gen you get? When I look at the list to buy online it doesnt say what generation it is.
Lets see if I get this correct..
Retrofit = Tearing open stock, and putting in HID?
the halos go around the projector. so technically if u see halos its surrounding a projector. however u can get projectors (such as the gen 4s) that do not have halos. halos are just a decorative light that looks cool. doesnt really serve a purpose other than cosmetics
if your looking at getting aftermarket lights definatly get HIDs. you will have much better light output and you will still have a proper cut off so it will not blind on coming traffic.
AWD > FWD
No you want hids trust me on that. You want them for several reasons. 1, The reason that the aftermarket projectors have issues with the lens spidercracking is the high heat from halogen bulbs. HIDs run cooler and will prevent this issue if you install them from the very start. 2, the projectors have much worse light output with halogen bulbs than the stock headlights, and you don't want that. HIDs when done in projectors look and perform great and don't bother anyone if you aim them properly. To avoid issues with them, get a relay harness and install it when you buy them, this way you draw power directly through the battery instead of through the tiny wiring the stock lighting uses, and avoid flickering and burning out wiring.
would it say give me
25mpg day time
18mpg night time? lol Im exagerating. But seriously if HIDS draw enough to require a relay, then is there some noticable drain on the engine?
As far as I can tell, all the aftermarket projectors come from China regardless of who you buy them from - fourth gen's might be the exception, have not looked too close at these. The quality is poor right out of the box and it doesn't take long for the covers to crack / peel, the led's to burn out, the wiring to fail......
Retrofit with hid's will be number one for usable light output but very expensive even if you do them yourself.
HID means high intensity discarge. Hid will without a doubt make the road brighter and mixed with projector headlights will be even more of a range of brightness. If you go with projos and hid... Make sure you buy some silicone to seal the projos because they use a shitty adheisive and you don't want moisture in the projos. You HIDs will not last very long if you don't reseal.
AWD > FWD
HID's draw LESS power once they are started - it's the initial surge of current needed to ignite them that kills the stock wiring.
on my 07 lt i had i got the gen 4's and did not get hids... they ended up spidering out.. in the other hand my buddy has gen 4's on his 08 ls and got hids right after... they are fine
get the gen 4's and hids, no probs, lights dont look cheap either
I just got my 4th gens and installed them this morning. I love they way they look but they need to be adjusted up. Anyways if i use HID in them do i need both bulbs on each side or is the highbeam bulb fine? i would like to save the headache of having to buy new lights just cause they mess up the casing. Is that link to the HID kits the best place to get them? do i just need the 9007 one?
asap man!!
dude I had Gen4's on my car before. I recommend you take those off and wait till you get your HID's on. You'll experience the stress crack occurring. I wished I knew about that before I gotten my HID's, now I got the crack on my left side as a result. I'm thinking about buying some stock OEM headlights off ebay and use the lens for the Gen4's so I don't end up throwing out my investment. Also, go to www.ddmtuning.com you'll save yourself some money and good quality. Had my DDM HID's for 3 months without issues.
