OFFICIAL Headlight and taillight options
#231
And yes they H7 bulbs
They suck there...gimme two seconds
#234
I'm in Mississippi now, I'm hoping to be able to get my plate removed soon, but they are rivited in so I'll have to have it licensed in MS if I want to go back to MO anytime soon. On more quick question did you notice if they were HID compatable, or do you have to modify them like the 1st gen headlights?
#236
#239
There is no way to take a headlight out to adjust it to call it easy.
All you have to aim is the lows thank god...and they are pretty close from factory.
Just be prepared to cuss a little
#240
Crap, I thought maybe these would be easier than the 1st Gen ones, I spent a week of playing with them to get them right. They were WAY off from the factory. I ordered a 55 Watt HID kit to put in this time, I'm hoping these will be a sweet setup when I'm done.
#246
If you get a flathead screwdriver or some other long, pointy metal object, you can turn the knob that adjusts the vertical positioning. The knob has teeth and kind of looks like a gear (or a cog or something) from the top.
If you want to adjust the horizontal, though, you're right, it does take a lot of work.
#249
okay i have a question for you guys before i go out and buy these things. i have an 07 and my headlights are the DRL's...if i go with the 2nd gen there should be no problem right? will the low beam work as my DRL's, or will it change over automatically to the halos for the DRL's. i have yet to find something that says what to do for the 07's (that doesnt mean it isnt somewhere lol). also if i go with HID's sooner or later i would imagine that would cause an issue as well with the DRL's right?
