Official Retrofit Thread
#1553
thinking of getting some retros for xmas this is the kit i was looking at. any input?
https://www.theretrofitsource.com/pr...roducts_id=237
#1554
The only reason to go with D2S version would be if you had shorter/shallower headlight and H1 wouldn't fit back there...
#1555
Yeah... go with H1 variant of the kit. It fits just fine in our headlights, H1 bulbs are cheaper to replace, and H1 version has slightly better light output.
#1556
#1558
Thanks I'll look, plus I found another. Is it a bad idea to simply buy projector headlights such as DEPO's
Lights & Bulbs - DEPO Projector Headlights (Chrome or Black) 05-10 Cobalt
And drop some HID's in the projectors? I don't want to melt the housing, but it seems like others have done it without claiming any negatives. And the cost is far more pleasing of course
#1560
What I mean is those headlights I linked already have projectors in them. I looked them up here on cobaltss and some people have simply put HID bulbs in them and say they are fine. I am wondering if this is a valid option
#1562
But a pair of decent bulbs and ballasts for an H7 is just plain cheap, with relay.
Edit: ugh looks like retrofit is the way to go
#1564
Frankly, I don't like the looks over an OEM retrofit either. But I was going to get a set of black OEM style headlights anyway, the the cost difference is pretty huge here if the performance is similar. If it's just a bad idea though I wouldn't do it (i.e. melting/cracking projector due to heat, bad cut offs).
#1569
I just finished up my headlight retrofits a couple of weeks ago and I decided to finally get some pics up. It's a style that has been done many times on the forums when searching through this thread but when I saw it I loved it.
These are FXR-3.0, Morimoto 4300k bulbs, Morimoto 3-five ballasts and gatling gun shrouds.
I was testing the led strips in this picture.
In this pic I don't believe the lights were on but the flash from my camera almost made them look like they were lit up.
Another with flash off.
All lit-up..
Daytime pic.
I need to get some better pictures but the weather around here has not cooperated with getting another wash and a photo shoot.
EDIT - Oh and no I don't have a bulb in the side marker lamp yet. If you look in the first picture you can clearly see that if I were to put a bulb in there for it then you would be able to see it around the projector so I left it out for now till I can come up with a better plan for illuminating those. I do want to get that done in the future though because they have my BiXenon stickers on them and it want that to show.
All lit-up..
Daytime pic.
#1570
Could you guys that use FXR, EVO's etc. post pictures of how you mounted them instead of just finished pictures that'd be great. I have a pair of RX350's I need to build but are un-sure of a good mounting method as theres really no holes to put bolts through.
#1573
#1574
