Outside Door Handle
Outside Door Handle
I'm pretty sure there is a thread of this but I can't find it.
My door handle outside of the car popped off, this happened to my driver side door but I had the dealership fix it when I was covered.
How do I fix this myself?
mostly the whole handle comes off and you can see in side the door.
Idk take the door apart and see what broke then replace the broken part
Panels pretty much pop and lift up&out to get off
sent from my craptastic galaxy s2!
take the door panel off. and look in where the post to the lock is. theres a little black grommet that goes around it. remove that and shine a flash light in there. theres a bolt in there i think 10mm. one thats directly straight and one which is to the left. the bolt to the left i believe you can stick a straight socket in one of those holes and can loosen the bolt that way. undo those and the door handle pops right out. i changed one to a sedan before.
http://www.g5club.net/howto/dnw/pw12.JPG
right below that foam square remove that little gromett
