View Poll Results: Is underglow to ricey for a cobalt
yes
189
43.35%
no
247
56.65%
Voters: 436. You may not vote on this poll
Is underglow on a cobalt to ricey
Old 09-30-2014, 11:19 PM
  #101
Jesse's Avatar
Originally Posted by silver cobalt SS
where do you guys hook up for pwr and where do you run the wires threw the dash for the switch. thanks...I wld like to put some lights in behind the grill
There is a grommet on the firewall that is easily accessible from the driver compartment. somewhere in front of the brake pedal. It's where I wired my wideband/ac/off switch. BTW the dimmer wheel trim on the far left is the perfect place for a switch.
Old 10-01-2014, 12:34 AM
  #102
Squints's Avatar
Necro a thread from 6 years ago what has happened to this site lol. It all depends on the desired location of your switch
Old 10-03-2014, 12:40 AM
  #103
silver cobalt SS's Avatar
thanks supernovanator...where do you run the wire for power?
Old 10-03-2014, 01:18 AM
  #104
Jesse's Avatar
I wired this
into a brown wire in the interior fuse panel, which is linked to the light sensor in the dash. This way they only come on when the headlights come on at night. Those were a bitch though and I had to run them individually. As in I couldn't hook the negative of one to the positive of another. They just wouldn't glow at all that way. So I had to ditch them when I got my sound system. Too much power loss.
My wideband I have spliced into the passenger airbag on/off light. This way it only comes on when the key is in the "run" position.
Old 10-03-2014, 02:03 AM
  #105
andrewcarr1993's Avatar
Well that's one way of showing off the panel gaps...
Old 10-03-2014, 02:28 AM
  #106
Jesse's Avatar
Believe it or not I had to grind some of the trim away so the light would shine. I wish I could wire them in series so I didn't use so much power but they are literally not visible even with only two wired in series.
Figured I could use the LEDs for something else and scrapped them though.
Superslowbaltt
09-22-2015 10:24 AM
Rayray2781@gmail.com
09-20-2015 01:52 PM
Bluelightning
09-08-2015 05:18 PM
jthwjde
09-07-2015 09:24 AM
Quick Reply: Is underglow on a cobalt to ricey
