RETROFIT Install questions and support!
#231
I guess I can take pics on how I hooked up the halos to a separate relay and switch
#233
EasySwitch Four Button Key Fob - Transmitter
Im thinking something like this might be cool. too bad its not one button, or rather have the trunk, door unlock, door lock, and halos on it.
#239
So this morning, I got in my dad's 7 series... I parked it pretty close to the garage wall, so when I started up the car.. I noticed something about the hids... the cut off was perfect, but I also noticed a line in the middle of each beam...
So I got out of the car it was the shadow of the bulb on the wall... then I realized I could see the position of the bulb... the insulator was straight up
So went over to my car, noticed my driver the one was upside down... and passenger was tilted..
Tightened passenger it was perfect
Driver.. no go, looks like from the manufacture they put the little tabs in the wrong spot.. so I filed one off... and bam PERFECT cut and color now matches lol
#240
ok....one last question.....Using the side marker on the headlight to wire up my halos.....Which one of the black wires are grounds....There is 2 black wires. I didnt wanna hook it up wrong and end up ruining the halo.
thanks
thanks
#244
oh ok just wondering. but why do they have a little angle on both of them to the right?
my car doesnt run right now so i cant pull it to much farther down the driveway. so idk if i am to close to the wall or what? but i would think it should all be flat
#249
