BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old 10-19-2010, 07:07 AM
  #301
mkulrey13's Avatar
Originally Posted by HB_SS/TC
I guess Ill check all the connections again but the passenger high beams don't work anymore
Sounds like your relay may have gotten wet
Old 10-19-2010, 09:45 AM
  #302
HB_SS/TC's Avatar
How much is a new one?
Old 10-19-2010, 02:11 PM
  #303
iboost's Avatar
i ordered those G3 harnesses...I was wondering if there was a status change on them yet?
Old 10-19-2010, 02:21 PM
  #304
kidcrash603's Avatar
Uh... We've been closed since the 12th, and we reopen on the 21st, so if you ordered during that time nothing has changed.
Old 10-19-2010, 02:29 PM
  #305
iboost's Avatar
gotcha
Old 10-19-2010, 06:50 PM
  #306
mkulrey13's Avatar
gotcha
Last i checked you paid for 1..you asked for a pair and the 2nd invoice wasnt paid for.
Old 10-19-2010, 09:14 PM
  #307
iboost's Avatar
check again please...i got 2 invoices...i paid both...both came out my account
Old 10-19-2010, 09:16 PM
  #308
mkulrey13's Avatar
Did you pay on 2 different days? Only showed one payment. They will go out when we open again
Originally Posted by hb_ss/tc
how much is a new one?
$59.99
Old 10-19-2010, 09:19 PM
  #309
iboost's Avatar
nope. paid 1 after the other. ill print screen my paypal if youd like...
Old 10-19-2010, 10:04 PM
  #310
mkulrey13's Avatar
ok as i said they will go out when we reopen. I only got 1 email about 1 payment. thats all. It shows you paid for 2.
Old 10-19-2010, 10:36 PM
  #311
JHans5774's Avatar
Did we ever get shipping reimbursed? Just wondering
Old 10-20-2010, 08:35 AM
  #312
iboost's Avatar
oh ok. Just making sure that everything is straight. Thanks again
Old 10-21-2010, 03:49 PM
  #313
xnigelx's Avatar
ok so what is getting wet that isnt water proof? and cant we just put some silicon on whatever it is to make it water proof?
Old 10-21-2010, 04:11 PM
  #314
mkulrey13's Avatar
The relay on the harness.
Old 10-21-2010, 04:17 PM
  #315
hook's Avatar
As far as i know no one has gotten this
Old 10-21-2010, 04:58 PM
  #316
zerosk8ter83's Avatar
i know whats up with that
Old 10-21-2010, 06:29 PM
  #317
xnigelx's Avatar
one last question i think, i tapped into the brown and black wires from the lil bulb for the halo but i dont think thats what i wanted. i wanted to make it so the halo only comes on when the fogs are on. i think what i did was make them so they are always on. so what wires would i tap them into? i do have HID fogs as well. Can i tap them into the stock fog connector that connects to the fog ballast? and if so brown is pos and black is neg correct? sorry i read the entire thread and i might have missed it
Old 10-22-2010, 11:19 PM
  #318
xnigelx's Avatar
Well here is a few pics from my install you can view all the one i took from here
Thanks again mike for the great kit. this was my first install of this kind and everything was pretty easy!
I did find the prongs you are saposed to switch in the blue connector like barely crimped. So everyone who hasnt installed double check those connections. I had to solder one of mine and crimp the other since it wasnt crimped. Other than that everything was a cinch. I was also kinda hoping the halos would be more yellow... they are pretty white upclose :/
Old 11-02-2010, 10:32 PM
  #319
stacy_dammit's Avatar
Originally Posted by zerosk8ter83
k guys here is the wiring for the low and highs to work on BOTH projectors
Right Projector wiring:http://i61.photobucket.com/albums/h7...9/102_1888.jpg
Left projector wiring:1 is brown,2 is blue and 3 is white http://i61.photobucket.com/albums/h7...9/102_1885.jpg
so yes its pretty much the same for both.If this does not work CHECK YOUR FUSES!!!!!! as for the halos i havent had any promblems BUT mine did go out for a while.All i did was unplug the halo wire that you connect to the ballast and plug it bak in and it worked again.hope this helped
So I started my retros a couple days agot. (taking my time)
I did this, but both lights still stuck on high. If i take out one of the high beam fuses, only that side will go back to low. If I take both fuses they both turn off. What should i do now.
Old 11-02-2010, 10:53 PM
  #320
Maupin SS/SC's Avatar
i still dont know how to repin im doing it wrong i feel like im break it can someone make a video
Old 11-02-2010, 11:31 PM
  #321
JHans5774's Avatar
Yeah one of my brights went out the pin thing is a total pita
Old 11-02-2010, 11:54 PM
  #322
come help me lol where do you live around here?
Old 11-02-2010, 11:57 PM
  #323
JHans5774's Avatar
I live in overland park we could meet up sometime and figure it out
Old 11-02-2010, 11:59 PM
  #324
xnigelx's Avatar
id double check the pins in the blue connector i had one light go out when i turned the brights on and it turned out being one of the pins didnt make it in. also check each pin to make sure the wires are crimped properly i had 2 of mine not crimped properly. u can also try swapping the blue and white wires again.
Old 11-03-2010, 12:00 AM
  #325
xnigelx's Avatar
take a small screwdriver on the pin side of the plug and push it in a lil the pin has a single barb u have to push in and then the pin will slide out the back with a lil tug on the wire.
Quick Reply: RETROFIT Install questions and support!
