BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old 11-13-2010, 11:55 PM
  #351
HB_SS/TC's Avatar
Originally Posted by corn-popSS
I appreciate the help.. I took it apart today when I put in my intake and when I looked at it, it was plugged wrong.. you were spot on!! thanx a lot for the help!!!
btw everyone, I'm hooking up my halos to a switch that I have inside my car for the led's under the dash. tomorrow it'll be done. I can post some pics if anyone is still wondering how to do this.
No problem glad I can help!
Old 11-14-2010, 11:45 AM
  #352
JoshuaVnyrd1817's Avatar
Originally Posted by Tunerfreak91
I have an issue where I think I'm running high beams all the time. I dont think its in the wiring, so maybe the relay isnt making the switch. On the automatic setting I it appears to be the high beams coming on, because when I pull the lever for actual high beams nothing happens. Not to mention that when the low beams (8k) are supposed to be on, they look like 4300k or 5k, very white.
Any ideas? Please help
Thanks
I got the same thing going on right now. I did everything the PDF install said to do as well as switching the wires around. My fog light kit from DDM took almost 5 minutes to install. Not sure why these relays are having so many issues but hopefully I can get a new one soon and hopefully that fixes everything... we'll see.
Old 11-14-2010, 01:27 PM
  #353
mkulrey13's Avatar
Relays have no issues..99% of the time its user error. Its been proven time and time again in this thread lol but Well get it worked out no worries
Old 11-14-2010, 04:30 PM
  #354
Tunerfreak91's Avatar
As of right now when lights are on automatic/low beams and I pull the lever for high beams, I can hear a clicking noise in the relay but the nothing happens with the lights. I'll check the 4 pronged wire but I dont think thats it.
Old 11-14-2010, 06:06 PM
  #355
kidcrash603's Avatar
Don't pull the lever, push it forward like you are supposed to, to have hi's on full time. What happens then?
Old 11-14-2010, 09:03 PM
  #356
Same thing happens. The relay makes a clicking sound but lights dont change either way
Old 11-15-2010, 12:07 AM
  #357
Is the clicking the relay or the cut off shield in the projectors? I thought it was the cut off.
Crash/Mike, I know what the relay does; when I get a new one that works, will I still have this problem too? I know that the relay technically does not have anything to do with the cut off shield going up or down. I thought that this might be happening because of the missing relay/ballast/bulb.
Anything else it could be besides the Ground, Power, not swapping the white and blue wires, or Plugs hooked up incorrectly???
Old 11-15-2010, 05:44 AM
  #358
mkulrey13's Avatar
mis-wired somewhere if i get this harness and it works fine lol
Old 11-15-2010, 12:32 PM
  #359
I sure hope it doesn't lol. The only thing I had to do was swap two wires and match plugs haha. I hope I can do that.
Old 11-15-2010, 02:44 PM
  #360
I dont know what the clicking is actually, just sounds like its coming from the relay. On another note, what swapping of white and blue wires are you referring to btw?
Old 11-15-2010, 03:37 PM
  #361
read back through this thread. if you don't know about that, it's probably your problem.
Old 11-15-2010, 08:34 PM
  #362
lol. Page 14 shows exactly how the wires should go. Your blue and white wires on the new relay harness need to be swapped.
Old 11-16-2010, 11:03 AM
  #363
CudaJoe's Avatar
anyone else getting a slight flicker in the light as the car moves?
Its almost as if I accelerate and the light starts to flicker "lightly" it almost looks like a strobe light set to the highest possible speed almost to the point that it would appear as if their was no strobe.
Old 11-16-2010, 12:10 PM
  #364
Maupin SS/SC's Avatar
its just your car shaking i think. i feeel like it happens too. its the cutoff it shows off more movement maybe!?
Old 11-16-2010, 12:17 PM
  #365
RedSuperSport's Avatar
mines been doing that to my light doenst flicker it shakes and i dont think its the buld i think it may be the whole housing shaking cuz its not all the way on right and i havent had time to check it out siince i installed them...
Old 11-16-2010, 02:05 PM
  #366
Ok so switch the blue and white wires on both projector harnesses and that should get the low beams on, I'll try that today
Old 11-16-2010, 02:11 PM
  #367
Ya if you look through this post theres a ton of pics and info on it. GL
Old 11-16-2010, 11:26 PM
  #368
Well I switched the blue and white wires on both the driver and passenger side. But my brights only work on the passenger side! lol wtf
Old 11-17-2010, 03:38 AM
  #369
xnigelx's Avatar
does ur driver side turn off when u put the brights on? cause mine did that and it ended up a pin wasnt in properly on the blue plug. if not try connecting the passenger side light to the driver side and see if it does the same thing. i think i also read that some people had to reswap the wires but only on one plug.
Also check the wires on blue plug to make sure they are making a solid connection a couple of mine had to be crimped/soldered
Old 11-18-2010, 04:26 PM
  #370
corn-popSS's Avatar
I had the same problem. check the round black 4 pronged plug and make sure the flat spots on it match up.. if you would just read through a little you would see where other people helped me with the same problem.. it'd save you a lot of hassle if you just read it all at once.. I found that out the hard way
if that doesn't work, then you've effed something else up.
Old 11-18-2010, 07:49 PM
  #371
Ya I've read most of the stuff. I don't see how people messed up the round 4 pronged plug lol, seems to me it only goes in one way. Anyway I looked a little closer last night and two wires got separated on the driver side headlight so I'm almost positive that was it lol. I've been doing work in the parking garage at UF where my car is, so light has been an issue. I attribute that to missing this earlier
Old 11-19-2010, 12:02 PM
  #372
corn-popSS's Avatar
if that doesn't fix it, make sure you check that 4 pronged round plug.. it's soft plastic and it'll still connect without the flat spots matching up.
Old 11-19-2010, 12:57 PM
  #373
CudaJoe's Avatar
I have verified that my right headlight does indeed flicker. At cold start I saw it flickering pretty badly so I got out and looked at it closely. no vibration, the flickers occur at random, its only the passenger headlight.
My guess is the connection to the + terminal is not holding up to well, or the wire has a short in it somewhere.. It would make sense that its a problem with power supply since the wire is that much longer to reach the right headlight. If the flickering gets any worse, I will investigate.
Old 11-30-2010, 12:50 PM
  #374
i still need to do my brights i couldn't get the pins out with a screw driver so i havent tried again. is it the tab on the top of the pin through the inside big opening? im going on a trip this weekend and its getting could so i need to do this now!
Old 12-01-2010, 05:08 PM
  #375
CudaJoe's Avatar
what can cause the flicker? Are there any specific points I should be looking at on these headlights? I scoped out my connection points to the power terminal and frame and they appear fine. I followed the wires as well and they seem complete and undamaged and zip tied in areas away from moving parts. Nothing is in a location where water can directly pour onto them.. Im confused as to why they are flickering now and they only flicker pretty much to throttle response?
Its just the passenger side headlight.
Quick Reply: RETROFIT Install questions and support!
