RETROFIT Install questions and support!
#52
Ok I got the screw removed.... Thanks for the help. Gotta give the lights one more coat, paint the reflectors , then clear everything and then just wait for the retrofit kit.
#53
How to remove deflector tab
Locate tab
Locate where tab is attached
squeaze tab till forks touch eachother
Remove
Kinda blurry but the end of tab is the forks
Tab
Tab removed from housing
Locate tab
Remove
Tab
#55
How to run fogs into running lights so they stay on with hi and low beams as well as only running lights.
Remove Headlight
Tabs, I have found a flat head works great
Headlight bolts (10mm)
Headlight Bracket 4 10mm blots
Locate fog light
All you need from a fog light is a ground and a power. I cut my wires out and just ran them as following
Blue is ground. (aftermarket wires factory color is different
Factory wiring color is brown for running lights. tap your power into this
fog light into running lights
tape up and reinstall and enjoy
Remove Headlight
Locate fog light
#56
Factory wiring color is brown for running lights. this is also perfect to tap your halo ring into btw
the blue wire is the blinker if you would like for your halos to flash with flashers!!!
#62
Now I know this isn't for your retrofit kits per say...but they are the G3 kits from 3b specs. I got them mounted and everything, but they came with this wiring harness...
Obviously that plug to the "headlight socket" isn't gunna work. Is there a way I can either rewire it or something to make it work for me?
#63
The easiest thing would have been to order H4/9003 hids, since that is what your harness is for. It might be possible to cut off that connector and wire in the correct one, but that means finding the correct one.
#69
#73
If you leave the DRL fuse in, you are asking your HIDs to fire every time you start the car, which will seriously limit their life.
#74
OK, so then there is no way to wire the halos to be on all the time? (other than to a voltage source from the fuse box) I like some light on (black car rural roads, so many mother f***ers have pulled out in front of me)
