BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old 09-14-2010, 11:54 PM
  #126
RHZ
RHZ's Avatar
you have to switch the wires on the other connector as well
Both sides are switched
Old 09-15-2010, 01:04 AM
  #127
RHZ
RHZ's Avatar
free scoobie snacks for anyone that can figure out this shitastic mystery. I've double and triple checked everything i can think of. I'm rocking passenger side brights until then
Old 09-15-2010, 01:05 AM
  #128
skatin_boarding's Avatar
Try changing it back and see what happens.
Old 09-15-2010, 01:23 AM
  #129
RHZ
RHZ's Avatar
when i switch them back then i can't turn from low to bright.
Old 09-15-2010, 02:28 AM
  #130
zerosk8ter83's Avatar
hmmm maybe you have to tap into another wire or something
Old 09-15-2010, 10:38 AM
  #131
Originally Posted by RHZ
I've switched the white and blue wires on the blue connectors... Now my lights will actually switch from high to low.
Only problem is my lights are opposite... passenger is stuck on high beam during low beam and switches to low beam when i turn on my high beams....
unhook one light, switch from hi to low, then plug in the other light back in
Old 09-15-2010, 05:21 PM
  #132
mkulrey13's Avatar
Try switching the blue/white wires back to normal then swap the brown/blue wire. Ive actually had to do that on a set.
Old 09-15-2010, 06:08 PM
  #133
mkulrey13 would the blue and white wires being crossed incorretly cause my brights and dims to be switched, (my dash says brights are on, but there is the cutoff). The lights work fine, and switch between dims and brights. I just want to make sure before i take the headlights back out again and adjust wiring.
Old 09-15-2010, 06:23 PM
  #134
morelos704's Avatar
i think i am having the the same problem, i have an 06 and i have them plugged in to adjust cut off but it looks like the highs are lit on the passanger side and lows on driver side, and switching them between high and lows it doesnt do anything
just to clear things up are these two wires that are circled the ones that need to be swiched?
Old 09-16-2010, 12:33 AM
  #135
morelos704's Avatar
also do i have to switch any of these around as well i go back to work on friday so i really need some help on fixing these by tomorrow, any help will be greatly appreciated
Old 09-16-2010, 02:27 AM
  #136
chowell_09's Avatar
question. How do we switch the blue and white wires on the 9007 connector? do we just pull them out and push them back in or what?
Old 09-16-2010, 05:32 AM
  #137
mkulrey13's Avatar
only switch the wires on the new harness, not the stock one. And you can use a tiny flathead to pinch the prong and then pull out.
Old 09-16-2010, 05:36 AM
  #138
morelos704's Avatar
yeah i saw the little tabs in there, do i do this on both clips?
Old 09-16-2010, 01:33 PM
  #139
Jaredssbalt's Avatar
whats the best way to adjust the cutoffs once lens is already back on? i got mine close while they were off but they are still a lil off. and what are the cutoffs supposed to look like? are they supposed to be flat in thwe middle then go up on both sides? and one more thing lol. i ordered the red halos and they are a peach or neon pink color is that how they are supposed to be or is it a defect? sorry to bomb you all with so many questions at once lol
Old 09-16-2010, 04:04 PM
  #140
morelos704's Avatar
ok i have switched the white and blue cable on the relay harness, and they are still not switching between highs and lows, and my passenger side light looks like its still stuck on high. i did notice that there is a click coming from my fuse box though
Old 09-17-2010, 12:56 AM
  #141
that clinking noise is coming from the projector when switching to low to high beams.I got mine to work somehow.Mine passenger side was stuck on low and didnt wanna go to high beam, didnt feel like messing with it.later that night i wanted to see how the one projector with high beam would look like and suprisily both projectors switch to high beam,awesome light!
Old 09-17-2010, 04:47 AM
  #142
morelos704's Avatar
did you switch any pins on the harness?
Old 09-17-2010, 06:54 PM
  #143
mkulrey13's Avatar
You need to email me with any problems. Support@buyhids.com.
Old 09-17-2010, 08:40 PM
  #144
LS6Rally's Avatar
did you guys have to grind off the "tabs" that place the 9007 bulb in the right orientation off? seems like the projector doesnt want to fit
Old 09-17-2010, 08:43 PM
  #145
CudaJoe's Avatar
Hi Mike I sent you an e-mail
Old 09-17-2010, 10:46 PM
  #146
morelos704's Avatar
can any one that has their retrofit kits properly working post the steps you took in achieving perfection lol...example: which wires you switched on the 9007 connector ect. ive read over the tutorial several times and quadruple checked all my wiring and everything is connected properly but my passenger side still stuck on high beam and my driver side still wont switch to high beam any help will be greatly appreciated
Old 09-18-2010, 01:59 AM
  #147
i will take pictures of the left and right wiring of the plugins.If your one of your projector is low and the other on high try lookinging at your fuses cuz that happened to me.
Old 09-18-2010, 08:55 AM
  #148
mkulrey13's Avatar
Guys, I will say this again..We test every projector before it leaves. If it doesnt work properly..something is not connected or crossed or something. And yes check fuses as well. 99% of the time its user error. Make sure your red/black wires are connected to a switched power source, also make sure your connector comming from the headlight is tight and the cap twisted on. Also make sure the pins in the blue connector are not bent from swapping the blue/white wires.
Old 09-18-2010, 01:09 PM
  #149
WickedSS2005's Avatar
My lights have been fine for a week until last night. One of the halo's went out. Wiring is secure, and nothing is loose... Email sent
Funny thing, my friend asked "did you wire up my new lights to wink at me?" haha... nope, but it was only one halo.
Old 09-18-2010, 02:04 PM
  #150
k guys here is the wiring for the low and highs to work on BOTH projectors
Right Projector wiring:http://i61.photobucket.com/albums/h7...9/102_1888.jpg
Left projector wiring:1 is brown,2 is blue and 3 is white http://i61.photobucket.com/albums/h7...9/102_1885.jpg
so yes its pretty much the same for both.If this does not work CHECK YOUR FUSES!!!!!! as for the halos i havent had any promblems BUT mine did go out for a while.All i did was unplug the halo wire that you connect to the ballast and plug it bak in and it worked again.hope this helped
Quick Reply: RETROFIT Install questions and support!
