BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old 09-19-2010, 04:10 PM
  #176
dayhoff35's Avatar
these are my first hids/projos so idk what theyre so theyre supposed to have the vs?
Old 09-19-2010, 04:17 PM
  #177
Maupin SS/SC's Avatar
I can't get my projectors to turn on at all i have it all hooked up and it had power and ground. There no low or high. What did you mean by switching wires i thought that was only to get highs also and since i dont have anything idk what else to try. and you sent me a fog hid kit that doesnt work.
the connector from bulb to ballast is fine but the connector to hook the relay to the original is both male hookups so im lost.
Old 09-19-2010, 04:43 PM
  #178
mkulrey13's Avatar
its user error if you have nothing working...also the fogs if your using the relay harness the 2 pins from the relay harness plug into your stock harness. the "male" plug plugs into your ballasts..
Old 09-19-2010, 04:49 PM
  #179
so the two pins go into the harness? theres pins on the bulb too?
Old 09-19-2010, 04:51 PM
  #180
mkulrey13's Avatar
I dont have it in front of me but i believe you do not use those pins if you are using a relay harness. When we open tomorrow i can be more helpful football is on :P
Old 09-19-2010, 05:18 PM
  #181
dayhoff35's Avatar
mkurley is the effect of the thing you were telling me about the projectors i bought showing on the page before this in my pictures?
Old 09-19-2010, 05:25 PM
  #182
mkulrey13's Avatar
I have no idea what your talking about.
Old 09-19-2010, 05:30 PM
  #183
loki141's Avatar
Anyone know what's up with my halo's? all the wiring looks good.. and everything else works.. drivers side lights up about half way around, passenger side nothing... wondering if the inverter box is crap, or what..
Uploaded with ImageShack.us
Old 09-19-2010, 06:03 PM
  #184
i got the fogs wired up without a relay i thought i HAD to use it cause it was weird looking compared to my old HIDs and now i have one headlight on but not the other. What wires am i gonna have to switch on the hids blue harness to have brights? BLue and White? If anyone had ideas why my passenger light isn going let me know
Old 09-19-2010, 06:16 PM
  #185
mkulrey13's Avatar
99% of people had bad grounds. Make sure you use the one that bolts the fendor to the car, Its just near the rubber stopper for the hood.
Old 09-19-2010, 06:17 PM
  #186
i did on both i followed the instructions exactly. how will those pins stay in
Old 09-19-2010, 06:19 PM
  #187
mkulrey13's Avatar
99% of all these errors are because something is wired incorrectly or left unplugged.
Old 09-19-2010, 06:20 PM
  #188
mkulrey13's Avatar
If your stock connector isnt crap/shot, they are wedged in between the prongs. throw some tape around them to protect them. im going on 2 years without issues with them.
Old 09-19-2010, 07:01 PM
  #189
ok all lights are working just gotta tape the fogs
Old 09-19-2010, 07:14 PM
  #190
CudaJoe's Avatar
Originally Posted by dayhoff35
aiming
i think my retros aiming is messed up i messed with them a little and passenger side one seems fine but the drivers side one looks weird
does it just need to be moved up more?
I have the something except its both projectors. They made mine. I think that's just the way the projector was made.
Old 09-19-2010, 11:42 PM
  #191
mine too...
what is needed to switch to highs? swapping the white and blue on the bixenon harness? my retros are done and working tonight except for that which ill do tomorrow night or something i brought my tools and stuff back to campus so i could do this
Old 09-20-2010, 02:07 AM
  #192
davebetterthanu's Avatar
Originally Posted by Tommyp2010
Looks to me like the passenger side is crooked and the drivers side is good.
Mine shines more to the right too I think that's how these are
Mounted my halos to a switch so it's cool to turn them on when I feel like it.
and for those still needing help for the passenger side ground I just added wire and put it where the driver side goes
Old 09-20-2010, 05:31 AM
  #193
mkulrey13's Avatar
Yes maupin, May i asked how you fixed your issues? Like to get all the answers in this thread to help people.
Old 09-20-2010, 05:32 AM
  #194
mkulrey13's Avatar
All projectors have a cutoff. Some may differ in shape but there designed to shine a tad bit higher on the right side to keep the light out of on comming drivers. Dont forget you can raise them with your stock adjuster in your headlights
Old 09-20-2010, 09:49 AM
  #195
i swtiched projectors the switched back to the other side. then both came on.....idk what was up with one. everything looks good i just need to switch the wires for the highs tonight? is there a speecial way to pull the pins out or am i better of splicing them in to one another farther back?
your ground wire is supposed to be that short i believe....!?
Last edited by Maupin SS/SC; 09-20-2010 at 09:49 AM. Reason: Automerged Doublepost
Old 09-20-2010, 09:50 AM
  #196
^if you look at the pins there's a little tab that's keeping it from going out. Push those down and it should pull right out. It should be the blue and white ones to switch
Old 09-20-2010, 10:24 AM
  #197
CudaJoe's Avatar
Woo got the halos hooked up to a switch
YouTube - Green Halos
show us your switch setup!
Old 09-20-2010, 10:26 AM
  #198
iboost's Avatar
is there a way to buy just the 9007 harness for the G3 projectors? If so how much...
Old 09-20-2010, 03:16 PM
  #199
mkulrey13's Avatar
There 59.99 Each.
Old 09-20-2010, 03:20 PM
  #200
iboost's Avatar
son of a....how do I go about ordering these?
Quick Reply: RETROFIT Install questions and support!
