RETROFIT Install questions and support!
#177
I can't get my projectors to turn on at all i have it all hooked up and it had power and ground. There no low or high. What did you mean by switching wires i thought that was only to get highs also and since i dont have anything idk what else to try. and you sent me a fog hid kit that doesnt work.
the connector from bulb to ballast is fine but the connector to hook the relay to the original is both male hookups so im lost.
#183
Anyone know what's up with my halo's? all the wiring looks good.. and everything else works.. drivers side lights up about half way around, passenger side nothing... wondering if the inverter box is crap, or what..
Uploaded with ImageShack.us
#184
i got the fogs wired up without a relay i thought i HAD to use it cause it was weird looking compared to my old HIDs and now i have one headlight on but not the other. What wires am i gonna have to switch on the hids blue harness to have brights? BLue and White? If anyone had ideas why my passenger light isn going let me know
#191
mine too...
what is needed to switch to highs? swapping the white and blue on the bixenon harness? my retros are done and working tonight except for that which ill do tomorrow night or something i brought my tools and stuff back to campus so i could do this
#192
Mounted my halos to a switch so it's cool to turn them on when I feel like it.
and for those still needing help for the passenger side ground I just added wire and put it where the driver side goes
#195
your ground wire is supposed to be that short i believe....!?
Last edited by Maupin SS/SC; 09-20-2010 at 09:49 AM. Reason: Automerged Doublepost
#196
^if you look at the pins there's a little tab that's keeping it from going out. Push those down and it should pull right out. It should be the blue and white ones to switch
