RETROFIT Install questions and support!
#211
Anyone have a diagram of the wiring for the hid fogs with the relay harness.....I looked at the one on the site but I have a bunch of wires with just prongs on them?
#215
Only prongs you use are from the relay harness and those plug into your stock harness.
#216
Ok.... There are a set of prongs with each hid bulb and the relay has just one set of prongs. What so I do with the set of prongs on the harness of each hid bulb
#217
that's if you want to use the stock wiring harness...
#218
So I just plug the one set of prongs from the relay harness into one of the harnesses for the fog lights? Then I must just tape up the ones on each bulb then?
#220
Those wires are incase you don't have a relay harness
#225
ok i wired it like this and bam my hi's and low work..... no lol
well this is what im getting.
passanger and driver side lows. working fine
flip to high beams
passnager side on and driver side out.
i used my power probe to test the white wire on driver side and nothing going to it not power from the controler i guess. i put power to it with my power probe and my high beam works once it got power. could the wire be lose or just bad all? i dont want to take the controler apart lol
flip to high beams
