Custom Tuning Results/Writeup!!
#52
Originally Posted by distillion
#57
Originally Posted by DWK5150
Yes it would but he even said in his first post that the ECM will be locked when they are finished tuning.
#58
Originally Posted by Mase
I'm asking for *.hpl files not *.hpt, "log" files which do not show the tune, just the output
#59
Originally Posted by meister
You can ask questions about the stock logs and I will be happy to answer what I can.
#60
With a mustang dyno, you cant change correction factor between non, SAE or STD like on a dynojet....it is always SAE. The only correction that gets applied is frmo temperature, humidity, and baro pressure....we have a weather station inside the building that samples all these numbers.
#63
why you afraid I'll see some number that don't match your dyno result. I'm not asking for your tune, I can send you my log files from when I dynoed at TAG
#65
Originally Posted by ninja44
I just might come see you next spring for a custom 2.7 pulley tune if you don't mind
#67
No, because you can see timing and other variables I do not want you to see. If you have a problem with it, dont post
The log file is an output much like dyno graph, the input is what really matters
#68
Originally Posted by 06blackg85ss
WOW.... can anybody ever just let somebody post something on here without starting a bitchfest..... this is starting to get real annoying... this is why we keep losing the guys that actually know what they are talking about
#69
With the 2.9 it boost about 120 Kpa and the 2.7 gets 140 Kpa (just over 20 psi) I'd actually like to dyno it to see what the car is doing (AFR) i get no detonation but would like to get a dyno to see what can be improved. I told myself I was done doing things to the car but damn my bike makes my car feel slow
#70
seeing what a car runs timing wise doesn't mean ****...I know a Redline that runs 26* up top but how do you get there is the problem.
If you want me to answer questions about the logs, let me know..
#71
If you sign a waiver, and really want us to tune this much boost on pump gas that is up to you
#73
You have my dyno charts, air fuel charts and that is all you will get....as I stated, my logs and my tune files are my property and I will be locking all my files too
#75
