HELP! Brakes!
check these guys out, I have a set of there front pads for my car which I haven't put in yet but I have used there pads before and had good results http://www.wpfri.com/index.html they are a Canadian company and do alot of testing on there pads. I am not sure if they do installations but if you give there number a call they will be able to tell you everything you need to know. also plain rotors are good I wouldn't reccomend sloted or cross drilled unless you want that for show.
Edit: tell them Ryan sent you, the solo2 guy
