Manitoba SS 2013
#627
Basically you nls from 1-2 and you get tire spin followed by traction control interference. I think that is where the killer is. And a 2-3 shift doesn't make up for the 1-2 shift being bad. I suppose you could always try nls from 2-3 only and on highway runs you may be doing 3-4 shift as well. (If I use 4th gear at the track it's for like 1/4 second.
I gain no mph by shifting into 4th gear making it a waste if time. My ets are the same either way. More power could help with this lol.
I could see a bigger gain with a stock ss tc as you don't usually spin the tires on the 1-2 shift very badly. And guaranteed you won't on the 2-3 shift.
More power than stock and your just pushing your luck anyway.
#630
Mike, or anyone else looking to cut weight and build
give it a read
Bodybuilding.com - Burn Fat Like Crazy With 3 Unconventional Cardio Styles!
give it a read
#631
I've been trifecta tuned for a long time prob 50K kms. I've had some warranty stuff done with no problems. I suggested the tune because after tuning there is no way I could ever go back to stock tune. Really transforms the car.
Of course HPT is your best bet. money and time will need to be invested.
Trifecta is cheap and fast.
After getting the hurst STS the car does feel much better however it still does not shift as nice as hoped for. Maybe the BPS will be better.
I still think you should check your roll pin it literally takes 5 seconds Bring it to my work and I can check if you want
And Dustin if I go back to Gimli it will be with meth and a HPT
#632
give it a read
give it a read
#635
#641
I want to try your 60"s first just to make sure. After that I will maybe try that PCM swap you suggested. I still need to do a leak down test too, did you ever ask your buddy about that? I have 500 KM's to go until I reach the 100,000 KM mark I am also tinkering with the idea of the head gasket too, but not right away. I am running out of ideas as to what the knock might be.
#642
give it a read
give it a read
#643
I am doing Kickboxing 5 days a week now. Plus jogging after class. Does not leave much time for anything else doing all that after a 10 hour work day. I sleep work and train. But exactly 3 months to go until my first fight.
#644
bulky foods (not junk foods)
#647
#648
Oh yeah ok I forgot sorry so much **** going on. Lets get your car going first then we can look at mine. As for the gasket, has nothing to do with knock just age of the motor, more a random thought the leakdown would help determine the nessesity of doing it.
#649
If you did want to bulk up be prepared to eat more than you could possibly think of lol. Like eat every day till you want to puke.
I eat 6 meals a day and it works great to stay lean. I would love to bulk up a bit but would go broke doing it haha.
#650
A head gasket either leaks or it doesn't. If it was leaking or needed to be replaced you would be burning coolant.
