Manitoba SS 2014
Old 10-19-2014, 10:51 PM
  #2826
tomj77's Avatar
Originally Posted by KMO43
If you turn off your meth there will be no voltage going to the pump therefor the failsafe will not be active
What the failsafe is looking for is that the pump is getting voltage. So for you with no box just a pressure switch if the pump seizes when not being used and you hit boost the pressure switch sends voltage to the pump but the pump doesn't move so no flow. The failsafe gauge sees that there is voltage and no flow so it trips the error mode you have setup. But if the failsafe sees no voltage there is no failsafe active
So what if the controller burns out or looses power? Then there won't ever be voltage to anything , therefore no failsafe? If that's how it works they need to do some improvements to this system. Can easily be fixed with another wastegate solinoid though.
Old 10-20-2014, 04:58 AM
  #2827
KMO43's Avatar
Ah ok gotcha. So if the relay to my meth kit failed the fail safe wouldn't trip. Gay haha.
Well nothing's perfect
Old 10-20-2014, 09:27 AM
  #2828
tomj77's Avatar
It would be so simple to make it perfect though.
Old 10-20-2014, 03:17 PM
  #2829
KMO43's Avatar
I don't think another solenoid is going to fix it I think you'll have drivability issues spool problems.
I think you're way over thinking this it doesn't even sound like you'll have a problem if it fails
Old 10-20-2014, 05:05 PM
  #2830
Got Bewst?
Bluelightning's Avatar
There's a much greater chance of my relay failing than your controller box. Perhaps I should look in to a stage 2 kit.
Old 10-20-2014, 05:53 PM
  #2831
KMO43's Avatar
What's this stg 2 kit?
Old 10-20-2014, 06:04 PM
  #2832
slapbetcommissioner's Avatar
Smaller pully bigger injectors and a reflash of the failsafe
Old 10-20-2014, 06:08 PM
  #2833
KMO43's Avatar
I know what the LSJ stg2 is I was wondering what a stg2 failsafe was
Old 10-20-2014, 06:10 PM
  #2834
Got Bewst?
Lol not fail safe, meth kit. I run the devilsown universal kit which is just a pressure switch and relay to activate the meth. Their stage 2 kit has a controller box.
Old 10-20-2014, 06:14 PM
  #2835
KMO43's Avatar
I'd buy the AEM kit it works with the failsafe let me look it up
Old 10-20-2014, 06:48 PM
  #2836
Got Bewst?
Where does the madness end though? Lol
AEM meth kit- $400, AEM fail safe- $250, solenoid- $100.
Doing some reading the AEM kit with no fail safe is pretty slick in itself. It doesn't monitor meth flow but does with everything else (wiring problems, overheated pump, low fluid) and you can set up a solenoid to cut boost if one of these parameters fail. So really, as long as your meth nozzle doesn't clog the AEM kit in itself can save the motor. Very cool
Old 10-20-2014, 07:00 PM
  #2837
KMO43's Avatar
Ya I think this will work way better for you because it will ramp it up and be easier to tune. If I had to do it again I'd buy the AEM kit for sure but I still like my 5th injector idea I think it'll work out the best
Old 10-20-2014, 07:02 PM
  #2838
tomj77's Avatar
I probably complicating things cause I like wiring up complicated stuff, lol its fun and I need an excuse.
<<<@!1!@>>>
snow solenoid is 65
<<<@!1!@>>>
snow solenoid is 65
Old 10-20-2014, 07:08 PM
  #2839
tomj77's Avatar
whats that witch craft ^ I never did it like that
Old 10-20-2014, 07:09 PM
  #2840
tomj77's Avatar
my snow kit is progressive like that, goes off maf airflow instead of boost. the more my airflow the more it injects.
Old 10-20-2014, 07:10 PM
  #2841
KMO43's Avatar
<<<@!1!@>>>
snow solenoid is 65
<<<@!1!@>>>
snow solenoid is 65
I think you'll have problems if you do a spool solenoid because my turbo will spool up before the meth starts to spray
Old 10-20-2014, 07:22 PM
  #2842
Got Bewst?
Maybe I'll just buy the meth kit and leave the fail safe kit. I mean I could run it for extra security I guess but where do you stop. An $800 meth injection set up is hard to swallow lol. Decisions decisions. Somethin to think about.
Old 10-20-2014, 07:35 PM
  #2843
KMO43's Avatar
Cheaper than a new engine you can use the kit in your next car or sell it
Old 10-20-2014, 07:56 PM
  #2844
Got Bewst?
For that price I should just buy a new 259et and run pump gas lol
Old 10-20-2014, 07:58 PM
  #2845
KMO43's Avatar
Do both... Go big this year!!
Old 10-20-2014, 08:26 PM
  #2846
tomj77's Avatar
I'm assuming u mean dual solinoid, wouldn't have an issue, Im not sure if u understand how I'd set it up. There are a few ways to set it up. I'd most likely just have it on wastegate pressure until my meth kit is turned on, then solinoid would activate and run through second solinoid which has a normal state of going through ecu boost control, which would get me full 28 lbs, if kit is turned off it would go back to wastegate pressure.
Old 10-20-2014, 08:38 PM
  #2847
KMO43's Avatar
That's exactly what I thought you were thinking of and I still think you'll have issues
Old 10-20-2014, 08:41 PM
  #2848
Got Bewst?
Lol perhaps if a turbo deal pending pans out. Gotta do some measurements first
Old 10-20-2014, 08:47 PM
  #2849
KMO43's Avatar
If you're measuring it's bigger than a 259et
Old 10-20-2014, 09:35 PM
  #2850
Got Bewst?
Time will tell haha
Quick Reply: Manitoba SS 2014
