Manitoba SS 2014
#440
So time for my annual question of what is causing my knock, only difference is this time I am gonna seriously try to fix it. So any thoughts what i should look for or try? Dustin we will do a leak down test for sure this spring once you Jalopy is up and going.
And Go....
And Go....
#443
Got Bewst?
Unplug your knock sensor and see if it keeps triggering. If it doesn't then electrical I would assume is good and something is actually making it come on. It only seems to start above around 5k like clock work. This never happened until you swapped your clutch so that may be the next step looking is yanking your trans back out.
