Manitoba SS 2014
#1405
Ya lol every one , but in this case
https://www.cobaltss.net/forums/lounge-42/getting-05-lsj-311537/
The getting an 05 lsj! Thread
#1419
Well boys, got the water meth kit mounted and tested again. Still works, lol doesn't vibrate the bracket . Had to take it apart and use different bolts cause it was vibrating like crazy. Now I just gotta wire it up and plum the line from the pump to the charge pipe, and also install new charge pipe modded for meth nossel. Should be fun project for a few days, cause I'm takin my sweet sweet time lol
#1420
I'm a little worried about the lower charge pipe with meth injection, it's a zzp pipe and the way it's made there is a 2 1/2 inch pipe till the throttle body up turn, then a larger pipe is welded on. Basically they pushed the smaller pipe inside the larger one and welded it, so , if u look inside the pipe from the throttle body end there is a shelf between the smaller and larger pipe because the smaller pipe goes inside the larger one about and inch and a half. I'm scared water will Accumulate and site there. Whoever has one should know what I mean. Is it anything to worry about?
#1421
#1423
I'm about to change out my Hahn crap to ZZP but I don't know where I'm gonna put my nozzle yet
#1425
