Manitoba SS 2014
#1577
Got Bewst?
I'm gonna order a mini AFC because my MAf scale is maxed so I'll have more adjustability running it. My meth kit may get thrown in with no fail safe if America does end up making his way up here so we can have some fun haha. Then I'll put that aem kit in over the winter.
#1579
If you change the number too much the ECU can't make up for it if the meth quits it goes closed loop I think it's called Term2 told me it was in the mid 20s on the LNF I was a couple % under that and I'm running the 625 nozzle on full pump pressure
#1581
Hey tom are what nozzle are you planning on running? Are you running a check valve? I installed mine in the fender with the washer res for the meth
#1583
Im actually running a solenoid between the pump and the thank, and I will be running a check valve just behind the nozzle. save a place for one of those aem fail safe flow meter, wanna get that eventually.
#1590
I believe the one that's on there right now is a 325ml/m whatever that is. that's the biggest one I have at the moment. I found a website that sells all kinds of meth stuff and there is only $8 shipping on anything I ship here, and no duty or anything. must be in Canada or something. got my tubing from there. and just ordered a check valve from there to.
#1591
I want a check valve because I was thinking, if im not using the system and im in boost, wouldn't the boost pressure push back into the tubing back into the pump and so forth? I know the solenoid stops it from going back into the tank but I just don't like the idea of boost pressure going back into the tubing, so that's why I got a check valve for just behind the nozzle. maybe be not needed but idk just peace of mind lol.
#1592
#1593
I don't mind this, only diff is that if I run mine empty I still got a lot of fluid left in the lines. lol which is fine, I live gavel road, which are sometimes horrible, and I know that the pump would be effed after a while even with a cover. want my stuff to last and stay clean, so trunk was best idea. it works good, once the system is primed and the tube is full of fluid, there is no wait time for fluid to go through lines. and the because of the the length of the line is why im having a check valve behind the nozzle, I don't want the fluid to be pushed back by the boost when its not activated.
#1594
You put the solenoid right before the nozzle and have it powered by the same wire that goes into the pump so when the pump is getting power it opens when it isn't it's closed. That way when you get off the throttle the solenoid will close right away and the pump still spins giving you a rich spike without the solenoid. So when not in used the solenoid is closed so no backflow
#1596
Ah no I understand , show says u should install this if u are spraying after throttle plate. But if it's in intercooler pipe ur system won't see any vacuum so there won't be any siphon effect. But I still see why this would be a good idea , I should move it. Or get a second one lol
#1599
