Manitoba SS 2014
Old 08-08-2014, 12:37 PM
  #1676
InfraRedline's Avatar
Very minor changes for starters. Added a little fuel in the mid range and only a half degree of timing in the upper end of things and took away a little bit of the other .5* dip we had. But it is about 2-3* more than the car was running before when it was pulling timing last time he tried 26 lbs.
  #1677
KMO43's Avatar
Went from around 11.8 to around 12.3
Wow that's more than I had thught so now since you're running more fuel and higher octane you should be able to get more timing out of it. Also if you went that lean but still had no knock imagine what it can do with proper A/F
Old 08-08-2014, 12:39 PM
  #1678
tomj77's Avatar
Originally Posted by KMO43
Water/Methanol FAILSAFE Device
It's what I was talking with Blue about a month or so ago
ya I got that bookmarked. my question is, how does it lower boost. with a solenoid? how does that work exactly?
  #1679
KMO43's Avatar
Hopefully it'll make a difference
Old 08-08-2014, 12:44 PM
  #1680
KMO43's Avatar
Oh ok you can do it many ways but an easy one is run a solenoid that has 2 inputs one from the boost solenoid and the other from normal manifold vacuum. So on normal operation it will just go through the solenoid as normal but when there is an issue it'll block off the stock boost solenoid and run straight manifold vacuum that will result is whatever the spring is set at so for stock turbo around 5psi
Old 08-08-2014, 09:48 PM
  #1681
Got Bewst?
Bluelightning's Avatar
Go to drive my car home from work and the rear drivers side tire is flat. Sure enough a 1" wide piece that almost looks like a razor blade is lodged into my tire like 1/2" from the side wall. So it's not even repairable. And I only have like 15k on the tires. What sucks ass too is I cant even go log my car on the new tune Taylor sent me now. ****** construction everywhere!!!!!!!! Now to try and find a new tire ASAP
Old 08-08-2014, 09:56 PM
  #1682
KMO43's Avatar
You don't have your stock wheels?
Old 08-08-2014, 10:20 PM
  #1683
Got Bewst?
Stock rims, no rubber
Old 08-08-2014, 10:25 PM
  #1684
KMO43's Avatar
That's no good Mark gave me his LSJ wheels so I have 2 sets now
Old 08-08-2014, 10:30 PM
  #1685
Got Bewst?
I can get one from Discount Tire Direct (where I initially got them from) for $195 Canadian to my door all in. I highly doubt any shop in Winnipeg is going to have Yokahama S Drive's in stock but i'll try. Worst case I order it tomorrow and get it in a few days.
Old 08-08-2014, 10:33 PM
  #1686
KMO43's Avatar
So you can't drive your car at all now?
Old 08-08-2014, 11:44 PM
  #1687
Got Bewst?
Oh ya I drove it home. I could put the spare on but that's ultra ghey. Whatever it is that's lodged in my tire is right on the side what doesn't contact the road and actually leaks very slow considering it's an inch wide. I just wouldn't want to wind my car out in 3rd gear with it haha.
Old 08-08-2014, 11:54 PM
  #1688
KMO43's Avatar
Oh I would not either I thought it was totally flat
Old 08-08-2014, 11:59 PM
  #1689
Got Bewst?
Thankfully it does hold air for a while. Can't be caught rollin on a donut
Old 08-09-2014, 01:22 AM
  #1690
KMO43's Avatar
Put the spare on the front then burn out city!!!
Old 08-09-2014, 03:30 AM
  #1691
tomj77's Avatar
well that would help me nothing since my wastegate seems to be 28psi.
Old 08-09-2014, 03:33 AM
  #1692
tomj77's Avatar
I just recently ordered 2 new conti extreme contact dw from Canadian tire. why from canadaian tire seeing as I payed like 260 each for em, cause for extra 9 buck each, if I destroy them in any way on the road, except normal use. I get new one for free
Old 08-09-2014, 10:23 AM
  #1693
Holy hell you guys get raped for tires up there. $195 for an S Drive?!!! Cody paid like $590 shipped for all 4 of his S Drives, and I barely paid a little more than $195 each for my R888's, granted mine are 17's, but Cody has 18's.
Old 08-09-2014, 10:30 AM
  #1694
SylverSS/SC's Avatar
we get raped on everything up here. The cost of living in Merica's hat!
Old 08-09-2014, 11:16 AM
  #1695
KMO43's Avatar
There are other ways of doing it you can get it you activate a ground or positive circuit or turn one off
Old 08-09-2014, 11:55 AM
  #1696
Got Bewst?
Yeeeep. $136 for the tire. Free shipping but $40 for duties and brokerage through customs. And $20 more for the US to Canadian dollar Exchange.
Old 08-09-2014, 03:58 PM
  #1697
tomj77's Avatar
So doing research I found out gunwash has everything u need for octane booster. And what do u know we use it at work for paint gun cleaning. Always get 4 50 gallon drums at a time. Hmmmm. I feel like I should get some and mix it and get the octane checked
Old 08-09-2014, 05:56 PM
  #1698
slapbetcommissioner's Avatar
If your getting it for free may has well just use 87 and boost that octain hah.
Old 08-09-2014, 06:51 PM
  #1699
Got Bewst?
Sounds like my buddy nick with an Audi S4. He's bound and determined to make high octane fuel with toluene lol.
Old 08-09-2014, 08:49 PM
  #1700
Lol. So he can buy regular? Or so he make 100oct
Quick Reply: Manitoba SS 2014
