Manitoba SS 2014
#2151
So Dustin I'm so jealous seeing in your log 7400rpm!! Are you close to maxing out the MAF sensor on your car
#2153
is it ok for fueliing to be maxed? Does he have to get a scaler?
#2155
Sorry i ment MAF to be maxed I saw he'sa at 80% on IDC
#2158
What injectors are you runing Dustin?
#2160
How much room is left on the?? can you run the 256et or would you need bigger injectors?
#2163
Taylor have time to look at that log? Did the WB work??
#2164
So Dustin how long does it take to hook up a meth kit?
#2166
I can change the scale of the gauge but if it's consistant just make up for the diff like 12.4=12.2 so just take .2 off
It's better to be read leaner than richer so you'll adjust to richen which is safer
#2169
Yep, like Dustin said it may be readin just slight leaner, but I'm going by what he says because I can't be in the car just yet, so he better not be a lying Canadian!
Thursday is Proving Grounds prep day for the Redline I plan to go over the suspension components/brakes and quick look over the car to make sure everything is ready for the trip next weekend, then put the WG spring and go find a nice road and tune to 30 lbs or so, see if I have enough injector as it sits or if I'll have to raise the base pressure a few lbs to get there. Then drive it the rest of the week and next week since it is supposed to get nice again, and then change the oil next week so its fresh for the trip!
#2170
Is the WB off by the same throughout the range?
#2171
Got Bewst?
It's really hard to say exactly. It changes so much through a pull right now. But I don't remember seeing some of the higher readings it's showed on the log. Top end looked close to spot on my wideband but showed 12.4 in one place in the log. It'll be easier to know once it smooths out a little.
#2172
If you did more pulls you can always go to the historgrams and get the avg for that cell
#2175
I think it funny the guy that said take 75-100 times with a grain of salt is now quoting his times because he had a good one!! PS I'll get you Dustin!!
