Manitoba SS 2014
Old 08-26-2014, 11:26 AM
  #2151
KMO43's Avatar
So Dustin I'm so jealous seeing in your log 7400rpm!! Are you close to maxing out the MAF sensor on your car
Old 08-26-2014, 11:30 AM
  #2152
InfraRedline's Avatar
He revs to 8k when he has more room! And yes the MAF is maxed at 5700 rpms lol
Old 08-26-2014, 11:33 AM
  #2153
KMO43's Avatar
is it ok for fueliing to be maxed? Does he have to get a scaler?
Old 08-26-2014, 11:44 AM
  #2154
Fueling isn't maxed, but control over the MAF is. Have to use the PE table to get things in line. He is going to be doing an AFC like I have over winter. ****, there is that W word again, fack!
Old 08-26-2014, 11:47 AM
  #2155
KMO43's Avatar
Sorry i ment MAF to be maxed I saw he'sa at 80% on IDC
Old 08-26-2014, 11:54 AM
  #2156
That's what I figured you meant. Yeah he has a ton of fuel left! 80% those injectors aren't even woken up yet
Old 08-26-2014, 12:04 PM
  #2157
Got Bewst?
Bluelightning's Avatar
8000rpm rev limiter FTW haha. That's really only useful in the 1320 lol.
Old 08-26-2014, 12:06 PM
  #2158
KMO43's Avatar
What injectors are you runing Dustin?
Old 08-26-2014, 12:08 PM
  #2159
Got Bewst?
80lb
Old 08-26-2014, 12:14 PM
  #2160
KMO43's Avatar
How much room is left on the?? can you run the 256et or would you need bigger injectors?
Old 08-26-2014, 12:18 PM
  #2161
Got Bewst?
Oh I got room fer dayz. Like Taylor said they aren't even workin right now. Plus once I start back up on meth my IDC will drop more.
Old 08-26-2014, 12:19 PM
  #2162
He will easily be able to run the 256et. They are only at 80% IDC on 26 lbs on this 252et. Not to mention he will be running meth too, so that will drop duty cycle a bit. Tons of room!
Dammit, you beat me to it lol
Old 08-26-2014, 12:21 PM
  #2163
KMO43's Avatar
Taylor have time to look at that log? Did the WB work??
Old 08-26-2014, 12:25 PM
  #2164
KMO43's Avatar
So Dustin how long does it take to hook up a meth kit?
Old 08-26-2014, 12:31 PM
  #2165
Got Bewst?
I already got a revised tune back lol. The meth kit I can have in in like 2 hours. It's the fail safe kit that may take some time.
Old 08-26-2014, 12:33 PM
  #2166
KMO43's Avatar
But did the WB work? hook that up and get to ordering the failsafe!
Old 08-26-2014, 12:58 PM
  #2167
Got Bewst?
Yup it worked. I think it's reading slightly leaner than what my wideband was reading but we will see as we get closer dialing in my target afr. Meth an mini AFC is my winter project.
Old 08-26-2014, 01:03 PM
  #2168
KMO43's Avatar
I can change the scale of the gauge but if it's consistant just make up for the diff like 12.4=12.2 so just take .2 off
It's better to be read leaner than richer so you'll adjust to richen which is safer
Old 08-26-2014, 01:07 PM
  #2169
Yep, like Dustin said it may be readin just slight leaner, but I'm going by what he says because I can't be in the car just yet, so he better not be a lying Canadian!
Thursday is Proving Grounds prep day for the Redline I plan to go over the suspension components/brakes and quick look over the car to make sure everything is ready for the trip next weekend, then put the WG spring and go find a nice road and tune to 30 lbs or so, see if I have enough injector as it sits or if I'll have to raise the base pressure a few lbs to get there. Then drive it the rest of the week and next week since it is supposed to get nice again, and then change the oil next week so its fresh for the trip!
Old 08-26-2014, 01:12 PM
  #2170
KMO43's Avatar
Is the WB off by the same throughout the range?
Old 08-26-2014, 01:32 PM
  #2171
Got Bewst?
It's really hard to say exactly. It changes so much through a pull right now. But I don't remember seeing some of the higher readings it's showed on the log. Top end looked close to spot on my wideband but showed 12.4 in one place in the log. It'll be easier to know once it smooths out a little.
Old 08-26-2014, 01:37 PM
  #2172
KMO43's Avatar
If you did more pulls you can always go to the historgrams and get the avg for that cell
Old 08-26-2014, 01:44 PM
  #2173
Got Bewst?
Ya I know. Wanna keep the lean afr pulls to a minimum tho haha.
Old 08-26-2014, 01:47 PM
  #2174
It definteily helps give me a solid idea of whats going on, mainly the AFR curve. Especially when having to find that MAF and PE table blend up top!
Old 08-26-2014, 01:56 PM
  #2175
KMO43's Avatar
I think it funny the guy that said take 75-100 times with a grain of salt is now quoting his times because he had a good one!! PS I'll get you Dustin!!
Quick Reply: Manitoba SS 2014
