Manitoba SS 2014
#2253
You guys missed out. Fun night for sure.
My buddies ZZP stage 2 gets the jump but I pull on him at the top of third. I need a tune so bad. Do LSJ's have longer gears?
NateSS' car lost to the ZZP stage 2 by about a car. His has a 2.9 pulley while my friend has 3.
#2262
He seemed to stay in second longer.
But that instant boost is crazy. First couple runs he shut it down right as I started pulling. Finally got one well into fourth and I started to pull ahead quickly. All three cars were pretty close.
I'm sure Nate's car just needs some maintenance things done and he'd be quicker.
#2265
Instagram
#2267
Ok here is what I have in mind. this is a mock up of a single pod, id make that and a 3 gauge pod. the holes where the vent controls go would be filled with plastic tab for when u mount the pod. it would slide in the back and be held in place by the vent backing that screws to the back of the vents. the vent tunnel is removable so it would be closed off completely or in the case of single pod it would only be closed on one side. that's my idea anyway.
