Manitoba SS 2016
Old 03-31-2016 | 05:17 PM
  #251
yellow dragon's Avatar
Sounds good I may want to do the same.
Old 04-01-2016 | 04:06 PM
  #252
Anybody know a guy with a blue redline. Not Mat Wiebe, this one was a brighter blue then his. Me and him had a good go at it the other day. had a big smile on my face after.
Old 04-04-2016 | 06:06 PM
  #253
heeter_33's Avatar
So is the Powell PCV system install really as easy as "Removing the dipstick and replacing it, and removing the pcv hose from the turbo are the toughest parts of the job."
I typically like to have some better visual instructions even though I can kind of picture what to do just from looking at it. How hard is it to get to the pcv hose on the turbo?
Old 04-04-2016 | 07:10 PM
  #254
nathan112i's Avatar
honestly is super easy if you destroy the hose when taking it off, just pry it off with a pair of needle nose pliers. if you don't want to ruin that hose then your best bet is using 4 metal zipties and lots of patience
Old 04-04-2016 | 07:15 PM
  #255
KMO43's Avatar
I believe u have to pull the fitting out and tap the VC
Old 04-04-2016 | 07:49 PM
  #256
heeter_33's Avatar
Well it did come with a tap, but the instructions didn't really mention tapping anything. Hence my confusion.
Old 04-04-2016 | 08:52 PM
  #257
tomj77's Avatar
not doesn't come with tap,use 1/8 npt tape. to get the current thingy out of the cover, just put needle nose plyer on either side, or grab it with a vice grip and then hit the vice grip with a hammer as close to the thingy as u can. tap it, don't have to hit hard. if it doesn't come, apply heat. mine came out super easy. when u tap the hole, put grease on the tap and the filings will stick to the tap instead of falling inside the valve cover. it really is very easy. if u have a zfr, I hope u told powell cause u need a 45 degree fitting for the turbo instead of the one he gives for stock turbo or ur line wont fit on
Old 04-04-2016 | 08:54 PM
  #258
tomj77's Avatar
Originally Posted by yellow dragon
Motion. We will work something out with Sheldon. Are you in too?
when is this dyno day, how much, and I thought motion was closed down
Old 04-04-2016 | 08:55 PM
  #259
KMO43's Avatar
Tom you gonna dyno as well?
Old 04-04-2016 | 08:58 PM
  #260
Bluelightning's Avatar
Got Bewst?
Nope motion is still goin. Just the dyno is at the owners place now.
Old 04-04-2016 | 09:12 PM
  #261
tomj77's Avatar
Depends on the price and time
Old 04-04-2016 | 10:01 PM
  #262
Got Bewst?
Last time I dyno'd by myself it was $125 for 3 pulls. I can knock that down with the more people that get in on a dyno day.
Old 04-04-2016 | 10:24 PM
  #263
KMO43's Avatar
I paid $150 for 4 pulls but Eric took time out to just dyno me the dyno isn't at his shop either and he is going to school
Old 04-04-2016 | 10:55 PM
  #264
heeter_33's Avatar
No zfr. I'm still kind of confused, but I'll think on it for a bit and probably have more questions when I actually go to install it.
Old 04-04-2016 | 11:06 PM
  #265
tomj77's Avatar
what version do u have? the one with the new manifold? latest one?
  #266
tomj77's Avatar
I asked walls to see how much they are. 225 to dyno, what a ripoff
Old 04-04-2016 | 11:21 PM
  #267
heeter_33's Avatar
Version 2
Old 04-04-2016 | 11:31 PM
  #268
Got Bewst?
Last time we did a dyno day with 4 cars it was $80 cash.
Yaaaaa I know I got ripped off by them once and never went back.
Old 04-04-2016 | 11:34 PM
  #269
Got Bewst?
Words can't explain the excitement of this 257 getting bolted up. Like a kid waiting for Christmas!
Old 04-05-2016 | 11:46 AM
  #270
tomj77's Avatar
Well when u got price let me know. I'm pretty curious about what I'm putting down.
Old 04-05-2016 | 02:53 PM
  #271
Got Bewst?
Sure no problem. Ya I'm excited so see the difference in power curves with my current 252 vs the new 257. No more boost drop and flow fer dayz
Old 04-05-2016 | 04:45 PM
  #272
tomj77's Avatar
Version 2
K let me know what u don't get ill help u
Old 04-05-2016 | 11:42 PM
  #273
heeter_33's Avatar
Gloria sent me some instructions that are more in depth. I'll go through those and any questions that arise will be coming your way.
Old 04-06-2016 | 10:15 AM
  #274
Well ordered some new rotors and pads yesterday off amazon. Cross drilled and slotted with black anti rust coating on them should arrive in a few days. Give em a shot. My fronts are pretty warped now so I need to do some thing. Should also look sweet just need to get some yellow caliper paint and do those at the same time.
Old 04-06-2016 | 02:27 PM
  #275
cluelessk's Avatar
Which brand. Thinking about ordering some Max Brakes. They're Canadian too.
