Manitoba SS 2016
#651
So you have owned your car since 09 and are just now modding it, and posting on this sight? Op cars are very different car to car. There is no 320-330-340 hp tunes. A tune that may give you 330 on 1 car, may give you 315 on another. Typically guys who want to know for sure, dyno after being tuned especially if you want to know shift point at max hp. It always helps if you do a before and after tune to see how much you pick up. But saying you are 330hp tuned may not be as accurate as you think. Most guys refer to hp as whp because they have dyno'd it on a chassis Dyno and know where they are. Just some info for you.
#652
#655
#656
Hahahahahahahaha. Thank you for making my day.
#657
Originally Posted by yellow dragon
To late anyway. The cut off to get in on the dyno was the 21st. I have to dyno it on another day as something else has come up.
#658
Can you stop and just listen to what people are trying to tell you? You're delusional and seem to think you understand what you keep regurgitating over and over again.
That 330 number is a slightly educated guess calculated by a program. It's not the same as dyno numbers which also change from dyno to dyno and across the different brands.
I dyno'd at 257whp with my stock TC. It's just not true. It's impossible. For true results you need to dyno before tune and after in the similar conditions.
Stop spreading this nonsense. With your mods you should be around 300whp.
#659
Y r u such a dick dude. I'm going by what my tuner told me who has experience tuning. I'll say it one more time to get it to stick in your head. I'm still learning about stuff like this. When I did pulls with the stock HP it felt fast but there was tons of room for improvement. Now when I floor it in second the wheels smoke. Obviously it's not exactly 330whp but it's quick. Maybe it's 310whp i don't know. I should dyno just for you cuz your so persistent in hating on me. Your username suits you
#662
I'm only trying to learn here. Cluelessk has a problem with me for some reason. This app is kind of hard to navigate sometimes and I wish I could delete some stupid posts I've made and I apologize to anyone who has to read this. I do say random **** and it may come out wrong but can't we all get along ?
#663
You're either not smart enough or too stubborn to accept real helpful information. You picked something (e.x. High whp number) essentially made up from thin air and keep on repeating it in thread after thread making you look bad. We're car guys, many of us work in the automotive sector. you can't string together automotive nonsense and think we'll believe you.
Also your "tuner" isn't your tuner. He unlocked your ecu ,helped you data log and flashed a tune from someone else.
You're way too active on the forum to be spreading nonsense. It's bad for the the forum which is already a shell of what it once was.
#664
#665
Originally Posted by KMO43
I've seen the post and yes it did get out of hand but where the misunderstanding came from is there is no way in HP Tuners to tell the exact HP of a car. I will compare 60 to 100 times to other cars I've tuned that have actually dynoed but that even has many variables. The only way to know is to actually dyno but then you car drive down the street hit another dyno with different results. I try to use term like ish and around until I actually hit the rollers. I hope that explains the misunderstanding
#667
I just don't like incorrect information to be trumped up like truth. We tried to explain it nicely. Even in other threads.
cluelessk (09-27-2016)
#669
#671
Even so you can go to 3 different dynos and get 3 different readings. Dyno numbers don't mean much. Power under the curve is what makes it.
Like a TC with a K04 makes say 300 whp. Well you make that for about a second then it starts to fall off on top because the turbo can't keep up. If you lined up with a 260whp car that makes peak power at redline, it'll end up hanging with or taking down a car with a garbage curve.
