Manitoba SS 2016
Old 02-16-2016 | 08:00 PM
  #126
cluelessk's Avatar
Pretty sure it runs on bushings and they wear. Mine's been making noise for years.
Check your cabin filter. Mine got way quieter after I put a clean one in.
Old 02-16-2016 | 08:53 PM
  #127
heeter_33's Avatar
All 3 of the cavaliers I've owned have done it. And the one year my Balt saw winter it did it. Dat GM quality.
Well that sucks, but kind of relieving. If it was just my car doing it I would be continually tearing it apart trying to solve it.
Now that I think of it I can kind of remember my dads sunfire doing it too. I think the sunfire gt i drove did it intermittently.
Old 02-17-2016 | 02:01 AM
  #128
Bluelightning's Avatar
Got Bewst?
Ya know the saying a Harley motorcycle is broken if it isn't leaking oil. Well a GM is broken if the fan isn't making horrendous noises lol
Old 02-17-2016 | 02:28 AM
  #129
KMO43's Avatar
Mine makes noise too
Old 02-17-2016 | 04:33 PM
  #130
tomj77's Avatar
They all make noise, u can buy a new better one for 120
Old 02-17-2016 | 06:53 PM
  #131
slapbetcommissioner's Avatar
Is it aftermarket or just off a higher end gm?
Old 02-17-2016 | 08:20 PM
  #132
cluelessk's Avatar
They're super cheap on Rock Auto. Might still be worth it
Old 02-17-2016 | 09:38 PM
  #133
tomj77's Avatar
After market I believe.
Old 02-17-2016 | 10:16 PM
  #134
Got Bewst?
Just sucks the whole dash gets torn apart to change it
Old 02-17-2016 | 11:27 PM
  #135
cluelessk's Avatar
Blower motor? You just cut it out with a box cutter and use self tapping screws with a bezel to hold in the new one.
Old 02-20-2016 | 06:16 PM
  #136
InfraRedline's Avatar
How are the Canadians doing?! I moved into my own place a few weeks ago and haven't got my internet hooked up yet, so I haven't been able to get on much lately. And whenever I'm at work I don't have much forum time lol
Old 02-20-2016 | 06:23 PM
  #137
yellow dragon's Avatar
Fantastic to hear Taylor.
Old 02-27-2016 | 05:05 PM
  #138
cluelessk's Avatar
Think everyone has Winter depression.
Been running regular in my car for the Winter. I idle a lot and my mileage doesn't really get affected, Plus it pulls enough timing I don't get knock.
Anyway I put a tank of 91 in just cause. It's a night and day difference. Biggest thing I noticed was the throttle response. 87 feels like the pedal is attached by an elastic band.
Old 02-27-2016 | 07:04 PM
  #139
KMO43's Avatar
I finally ordered my stg2 cams
Old 02-27-2016 | 07:59 PM
  #140
heeter_33's Avatar
Would there be a similar noticeable increase going to 94? I've never actually tried 94 yet, despite always working at Husky sites. Figured it wouldn't be enough of a difference from Shell without a tune to bother.
Old 02-27-2016 | 08:02 PM
  #141
KMO43's Avatar
Oh ya!! Like a min gain of 3* timing!! On my R holding 25psi to 6500 I ran 15*!! on 91 will 21psi I get around 12*
Old 02-27-2016 | 08:12 PM
  #142
cluelessk's Avatar
On stock tune I doubt it.
Old 02-28-2016 | 12:00 AM
  #143
Stock tune you won't see a difference. Definitely between 87-91 as the computer on the stock tune has two different timing maps. 91-94 would be the same timing map thoigh so the difference would be negligible. Unless your getting knock I wouldn't bother
Old 02-28-2016 | 12:04 AM
  #144
KMO43's Avatar
LSJs have the 2 maps LNFs don't.
Ps like taylor says nobuddy gots time for stock tunes!!
Old 02-28-2016 | 12:17 AM
  #145
I swear they did. Learn something everyday.
Old 02-28-2016 | 12:21 AM
  #146
KMO43's Avatar
They have 4 tables for cam position not a low / high octane table
Old 03-01-2016 | 12:57 PM
  #147
Well seeing as the 1st day of spring is only 19 days away. Gotta start figureing out issues from end of season last year. Gotta figure out how to stop my meth leaking. the solenoid for the meth is whats leaking where the hose goes in. the fitting is one of those pressing fittings, the hose is one of those nylon tubing. Thoughts? any other fitting work with the nylon tubing should i try for a straighter shot for the hose into the fitting as it kinda pulls to one side a bit. Thoughts?
Also gotta figure out some summer tires. Dustin? Still thinking of selling the yoko's?
Old 03-01-2016 | 08:27 PM
  #148
Got Bewst?
There really should be no reason for it to be leaking unless the hose was on a good angle and pulling on the quick connect. Perhaps try a more straight shot at the fitting.
That's a good question I'm not really sure what I'm doing for tires yet lol.
Old 03-02-2016 | 01:03 AM
  #149
cluelessk's Avatar
I'm probably gonna get a set of Nankang NS-2R. They're a DOT approved summer comp tire for not too much.
They come in two different treadware ratings. 120 and 180. 235/40/18 is $133.
https://www.canadawheels.ca/tires/nankang/ns-2r
Old 03-02-2016 | 03:18 AM
  #150
Yeah those are pretty cheap
Like to see some revues on them From some cobalt owners
