Ontario E-Test with no Cat
Old 11-29-2015 | 02:49 PM
iammancini's Avatar
Sorry if this has been posted, but is it possible to pass etest with no cat. Can an HP Tune place the ECU in a state that reads "ready." Is there anything else that i should be concerned about.
Does anyone know of place to get a zzp or equiv downpipe in toronto area that wont kill me on shipping and a HP tune. ive seen adds on kijiji for a place in kitchener called darkknight tuning. are they any good?
Old 11-29-2015 | 02:52 PM
You cant use hptuners to make the computer ready, but you can use this device called an o2 defouler. Google it
Old 11-29-2015 | 02:54 PM
iammancini's Avatar
have you passed e-test with this defouler? should i just play it safe and get a highflow cat?
Old 11-29-2015 | 03:25 PM
Personally i have not because where im registered does not require testing. But i know others who have had success using it.
Also sometimes with a high flow cat, you still have to use the defouler.
Old 11-29-2015 | 04:15 PM
iammancini's Avatar
ok thanks for your help.
one method around would be to swap back to stock cat but that would also require changing back to stock tune i presume
Old 11-29-2015 | 04:56 PM
not necessarily. as long as you dont drive it too hard or keep it on for longer than you need to it should be fine to test with the stock downpipe on.
Old 11-29-2015 | 05:02 PM
My dp has the bung and it passes the ob2 check I have the turboxs one also of you want a deal with zzp, tomorrow they won't be charging shipping internationally
Old 11-29-2015 | 05:06 PM
iammancini's Avatar
ok, still cant decide what route to go. i need to make sure it will pass e test.
Old 11-29-2015 | 05:43 PM
Hopefully a Canadian can shine in
Old 11-29-2015 | 06:50 PM
iammancini's Avatar
yes, surprised there isn't more info on the subject.
Old 06-05-2016 | 09:57 PM
BoostedJ's Avatar
Yes, you can.
I did it on my 3800 swapped Sunfire, passed etest without any issue. (Ontario, Canada)
Old 06-19-2016 | 11:33 PM
sLAsh's Avatar
Needed the defouler to get my lsj to pass with the zzp high flow.
pmerritt
12-31-2015 02:30 AM
dennis69
12-03-2015 11:44 PM
NihontoSS
106
12-02-2015 08:51 PM
Zooomer
82
12-02-2015 08:36 PM
dennis69
11-29-2015 09:42 PM
