Calgary - random talk thread
the hinge holes are already drilled. just gotta cut out the latch mechanism hole. It also looks like it's fiberglass underneath and the outside is carbon fiber. not sure if that's right or not
Joel
Concentrations Effect
10 ppm or less No known short term effects from 8 hr exposures.
20 50 ppm Eye, nose, throat and lung irritation.
50 100 ppm Marked eye, nose, throat and lung irritation.
100 150 ppm Severe eye, nose, throat and lung irritation. Loss of smell.
Exposure duration of 8 hours or more may be fatal.
200 300 ppm Headaches, drowsiness. Prolonged exposures of several
hours may cause the lungs to fill with fluids.
300 500 ppm May cause unconsciousness and death in 1 to 4 hours.
500 700 ppm Knockdown (may be fatal) with 1 hour exposure.
Greater than 700 ppm Immediate knockdown (may be fatal).
Hey Jon, friend of mine has a performance shop in nw just of 32nd. He does absolutely wonderful work and stands behind everything, won't let it leave unless both you and him are happy
bummer.
how's the fit on it?
are you going to add a trunk lock?
basically if the trunk needs to be tweaked ~ then it would have to get re-cleared or painted.
BUT!
if it's a jellcoat issue, (from what I've gathered) that's a whole different deal...
BUT!
^^^this thread sometimes is hopping for weeks on end;
other times it slows down for a breather
it seems as though right now some of the regulars in this thread are posting in the dungeon, or lurking
