Calgary - random talk thread
Old 10-03-2012, 12:52 PM
  #27376
jrmotosports 88's Avatar
sounds good man see u when u get here............
Old 10-03-2012, 01:00 PM
  #27377
DiabeticKripple's Avatar
Jonathan, should i get a retune cause I run 94 now and since te stations switched to their winter blends?
Old 10-03-2012, 01:49 PM
  #27378
victoryredturbalt's Avatar
the perfect example of whats wrong with america's youth right there....
who is 'cobe'?
Old 10-03-2012, 01:56 PM
  #27379
lol a member from mich..... just hit new post and u will find a post
Old 10-03-2012, 02:49 PM
  #27380
what time were you thinkin jonathan? i wont be here after work due i have to do a job for my dad... i would be able to be here tomorow tho.....
Old 10-03-2012, 08:09 PM
  #27381
i have finally met the beast within my car and man its nasty..... thx jonathan its exactly what i thought it would be.......
Old 10-03-2012, 11:32 PM
  #27382
soundjunky's Avatar
I'm glad you're happy Mark.
you have my number(s) if you have any problems, or if you decide to change something and want to do a datalog to update it...
Old 10-03-2012, 11:51 PM
  #27383
thedude411's Avatar
He went trifecta?
Old 10-04-2012, 12:28 AM
  #27384
soundjunky's Avatar
Originally Posted by thedude411
He went trifecta?
yup.
you never finished up your tune with me...
and iirc your tune was initially ordered for a M62 & 2.6" ~ then you went to a TVS & 3" which was deemed close enough to use the same "base", which we fine tuned, in anticipation of you downsizing your pulley this spring...
You're HPT now right?
Old 10-04-2012, 12:30 AM
  #27385
jonathan did you see my post above?
Old 10-04-2012, 12:43 AM
  #27386
thedude411's Avatar
I'm supposed to be. I bought Joel's HP tuners end of may or beginning of June and I still havent received it yet. I'm not sure what the future of the cobalt is and nothing is probably going to get done until spring since I still haven't put it back together yet.
Old 10-04-2012, 12:59 AM
  #27387
soundjunky's Avatar
nope, I didn't notice it;
I wouldn't say it's not worth the time;
when you're pushing a boosted car, and you're going to regularly run a gasoline that is vastly different from what it was set up for then yes;
but with small changes (as in ALL the canadian pump gas), your ECM does already compensate for the small variation in octane rating.
87-89-91-94
as I've understood it so far, a naturally aspirated (<10:1 compression) engine simply doesn't make enough heat to worry about knock, or the ECM's ability to compensate in pump gasoline differences.
now with boosted engines you can quickly make too much heat for lower octane gasoline - which in turn necessitates a "minimum" octane gasoline to use;
with respect to E85 (85% ethanol, 15% gasoline) the fuel tables need to be vastly changed from that of regular gas - you need to run much richer with the E85 ~ which could be out of spec for the CC rating, and available duty cycle of the injector used.
does that sound sensible?
Old 10-04-2012, 01:01 AM
  #27388
sounds good
Old 10-04-2012, 01:05 AM
  #27389
soundjunky's Avatar
sounds good
also, not many people realize it, but canadian regulations do not *require* the gasoline actually be as it's advertised;
it can be several points lower than the rating at the pump.
if you look at the fine print on the pumps - some of them actually spell this out.
Old 10-04-2012, 01:39 AM
  #27390
lol its funny you said if i had problems to give ya a shout..... well expect a call in the morn hahahahaha i ooooooooooooooooooooooooooooooppppppppppppppppppps sssssssssssssssssssssssss...... i hope things will be fine in the morn but in case it isnt i might need you to pop over after work..... i need a interceptor.....
Old 10-04-2012, 01:44 AM
  #27391
soundjunky's Avatar
uh-oh.
I have a birthday party for my niece at 6:30 iirc...
you still have my card right? - if you do, call the direct number.
Old 10-04-2012, 01:48 AM
  #27392
i will probally try autovalue in the morn and if all else falls thats when you get the call.... i think i blew a sensor somewhere...... tossed a code in limp mode as we speak..... car is at the shop..... it was a funny thing coz blacksmoke was just saying this thing pulls hard and yep you get the picture....
Old 10-04-2012, 01:55 AM
  #27393
soundjunky's Avatar
I can also pop by at lunch tomorrow.
the trifecta software has a pretty good scanner...
not as good as the HPT deal, but at least as good as any aftermarket generic scanner.
Old 10-04-2012, 01:57 AM
  #27394
ya i will shoot u a pm tomorow lol i am so sorry hahahahahaahahahah but when it happened i was squeeling like a school girl....... so you know at least it cant be to serious coz im grinning ear to ear......
Old 10-04-2012, 03:13 AM
  #27395
PsychoGenius's Avatar
If its an LNF, i put mine into limp mode with a NLS from 1st to 2nd the first day that I was tuned. I just did a battery reset and it was fine after that. I have had a couple misfires if Im shifting high in the rpm band at the track, but thats probably due to the stock plugs. Gotta find me some -2 plugs somewhere's.
If its an LSJ... well there's your problem
Old 10-04-2012, 10:15 AM
  #27396
lol well i am still smiling so its a lsj..... and ya disconnection of the battery didnt work..... not sure if i should risk driving it to autovalue...... and i think its best if i wait for jonathan to come over when he can lol..... i pretty sure i blew the o2 or camshaft position sensor..... lol at least thats our guess.....
Old 10-04-2012, 10:30 AM
  #27397
soundjunky's Avatar
let's just play it this way Mark;
I'll come down for lunch.
I put my computer back in my car this morning.
Old 10-04-2012, 10:40 AM
  #27398
yeppers and jonathan thx......... hahhahaha im sorry but i never been so happy to break my car...... i cant stop laughing..... i wont make this a habbit..... but it has happened and man im smiling hahahahahah
what you want for lunch jonathan i will go get some eats...........
Old 10-04-2012, 10:46 AM
  #27399
soundjunky's Avatar
thanks for the offer Mark, but don't worry about it, I have stuff here at work.
let's face it, it's not like I have to drive half-way across town to get to you ~ so it's no bother.
I probably won't be able to stick around long though, I'm a little behind the ball with work today.
Old 10-04-2012, 11:26 AM
  #27400
SylverSS/SC's Avatar
you guys are a bunch of homos! lol
Quick Reply: Calgary - random talk thread
