Calgary - random talk thread
It's stock gm bearings you use. When you get them out you will notice connecting rods had Tangs recut. This was due to zzp error and I had to get machine shop to recut and fix
I'm doing good mark btw. Just got my trucks drivetrain complete. 450ftlbs torque, 425 hp and bolting up 100 shot nitrous tranny built to handle 600. All good. We should all et together after xmas
yes agreed we should gather in the new year it would be good to see you.....
btw downshift meet tjay^^^^^^ sorry i dont remeber your name downshift, but dont worry or take offense.... barely remeber sylver's name too.... i usually refer to him as bitch.... lol or as bish would say my bf.....
btw steph welcome to our hell, turn and run bish lied we are weird.....
Thanks man ya I'm gonna go some calling tomorrow an see what I can find
@jrmotosport hey man you got that motor in your back yard what's the bottom end on it like would it be possibly worth it to score the bearings out of it or would they be grooved to that crank and not good for a swap ?
It's Brian by the way sorry for the typos I'm on my iPhone in the garage
if you spin rod bearings, odds are the crank end of the connecting rods will need to be resized;
if there is sufficient scoring to the crank (sometimes you can simply polish it) then the crank will need to be reground.
- to pull rods, the top end must come off.
- to pull the crank the transmission has to come out.
- you can polish the crank with the short block in place, and transmission in place.
odds are regrinding or resizing what you have will be cheaper than buying new, shipping from the USA, and dealing with duty/brokerage... it just will be more time consuming.
once again, if something cheap/quick might be preferred, it might be most economical to buy a replacement motor (if one can be sourced in AB) - but Tjay gad some choice parts in that engine.
car-part.com
i think the best local yard for cobalt parts is forest lawn auto parts.
your engine was specific to 2004-2007 Saturn Ion Redline & 2005-2007 Chev. Cobalt SS/Supercharged.
if i am looking for engine parts, most local retailers no longer stock stuff - as long as you've triple checked your measurements I can give you a shop to call about sourcing parts.
No need to buy "GM" parts for your engine - that's just paying a premium for parts being sold in a GM box.
please don't take offence by any correction.
if you've spun bearing(s), please don't waste your time/money on changing out bearings without resizing the rod.
did you do a compression test, as suggested, before you dropped your pan?
(I sure hope so)
Maybe Tjay can chime in about how to go about setting (or how much of a pita it is to set) the timing chain.
Well Sean thinks its just a main bearing not a rod bearing but I'm just gonna change them all out while I got it apart but we will know more tomorrow night when we really get in there and check it out and no offense taken I'm the rookie hear I would rather any suggestions or advice I can get
to pull main bearings you need to pull the transmission to drop out the crank.
ya i dont have motor anymore, besides as stated already never swap out bearings to put used ones in....
there is a big diff in correcting someone, as to 3 people jumping down someones throat for something that was completely UNIMPORTANT!!!! besides if you didnt read it correct we were all wrong.... even at that number i believe is too high too.... the car was governed at 225.... you think about that....
besides that since when did i take offense i would just go over to all your houses and slap you around before offense was taking....
I know I come off overly cereal at times, but you seem to at times take offense...
@ Will;
Technical talk is fun
@Downshift;
If you need other assistance I'm sure that Jon or myself can pop by.
PLEASE, PLEASE, PLEASE - what ever you do, don't take apart the bottom end without doing a compression test.
(you never clarified if this was done).
There's an old addage I earnestly try to stick to:
KISS
Keep
It
Simple
Stupid
If you jump to worst case scenarios (as I often have tended to do) - you can get in over your head in what could have been a realatively easy/cheap fix.
also, can anyone tell me if O2 sensors are covered under the (limited) powertrain warranty?
I think mine's on it's way out...
I do have a spare *somewhere*, but if I can get a new one, installed for free, I'd be all over it.
pass side and will scooped it a long time ago............
i smell meth going your way, hahahaha i guess the lsj's are getting a lil to close for comfort hey...
i may have a sensor around but god knows where............ i can look for you.... jon may have one on the manifold on the spare motor...
