Calgary - random talk thread
Old 12-17-2012, 10:38 PM
  #28601
SylverSS/SC's Avatar
Ya that is a good point
Old 12-17-2012, 10:41 PM
  #28602
cli3e0339384398jk's Avatar
It's stock gm bearings you use. When you get them out you will notice connecting rods had Tangs recut. This was due to zzp error and I had to get machine shop to recut and fix
Old 12-17-2012, 10:42 PM
  #28603
Might want to do leak down test and ensure top end is good as well ( you may have bent a valve or tore a seal with sudden down shift.
Old 12-17-2012, 10:48 PM
  #28604
I'm doing good mark btw. Just got my trucks drivetrain complete. 450ftlbs torque, 425 hp and bolting up 100 shot nitrous tranny built to handle 600. All good. We should all et together after xmas
Old 12-17-2012, 10:52 PM
  #28605
jrmotosports 88's Avatar
yes agreed we should gather in the new year it would be good to see you.....
btw downshift meet tjay^^^^^^ sorry i dont remeber your name downshift, but dont worry or take offense.... barely remeber sylver's name too.... i usually refer to him as bitch.... lol or as bish would say my bf.....
btw steph welcome to our hell, turn and run bish lied we are weird.....
Old 12-17-2012, 11:51 PM
  #28606
DownShift's Avatar
Thanks man ya I'm gonna go some calling tomorrow an see what I can find
@jrmotosport hey man you got that motor in your back yard what's the bottom end on it like would it be possibly worth it to score the bearings out of it or would they be grooved to that crank and not good for a swap ?
  #28607
soundjunky's Avatar
holy crap not you too...... fine i will not share any info with you all again wow........ sue me......
there's a vast difference between friends correcting each other and suggesting someone is stupid.
I wouldn't go there.
Old 12-17-2012, 11:53 PM
  #28608
DownShift's Avatar
Will do for sure thanks so the help everyone appreciate it as I'm trying to learn
Old 12-17-2012, 11:56 PM
  #28609
DownShift's Avatar
btw downshift meet tjay^^^^^^ sorry i dont remeber your name downshift, but dont worry or take offense.... barely remeber sylver's name too.......
It's Brian by the way sorry for the typos I'm on my iPhone in the garage
Old 12-18-2012, 12:05 AM
  #28610
Residental Bish.
Baltbitch's Avatar
Fancy that I'm also on my iPhone on the garage...
Old 12-18-2012, 12:08 AM
  #28611
soundjunky's Avatar
Originally Posted by DownShift
Thank man will do just dropped the oil and we found out it is the bearings so ill get ahold of zzp in the am and get a set ordered we are renting a heater and swamping then out this weekend so hopefully be up and running by monday
please don't take offence by any correction.
if you spin rod bearings, odds are the crank end of the connecting rods will need to be resized;
if there is sufficient scoring to the crank (sometimes you can simply polish it) then the crank will need to be reground.
- to pull rods, the top end must come off.
- to pull the crank the transmission has to come out.
- you can polish the crank with the short block in place, and transmission in place.
odds are regrinding or resizing what you have will be cheaper than buying new, shipping from the USA, and dealing with duty/brokerage... it just will be more time consuming.
once again, if something cheap/quick might be preferred, it might be most economical to buy a replacement motor (if one can be sourced in AB) - but Tjay gad some choice parts in that engine.
Old 12-18-2012, 12:13 AM
  #28612
soundjunky's Avatar
even if it was there, you NEVER swap used bearings from one engine to another.
car-part.com
i think the best local yard for cobalt parts is forest lawn auto parts.
your engine was specific to 2004-2007 Saturn Ion Redline & 2005-2007 Chev. Cobalt SS/Supercharged.
if i am looking for engine parts, most local retailers no longer stock stuff - as long as you've triple checked your measurements I can give you a shop to call about sourcing parts.
No need to buy "GM" parts for your engine - that's just paying a premium for parts being sold in a GM box.
Old 12-18-2012, 12:21 AM
  #28613
DownShift's Avatar
K ya Sean is coming over tomorrow night to double check everything but it doesn't look like the crank is scored at all
Love it
Old 12-18-2012, 12:24 AM
  #28614
DownShift's Avatar
Well Sean thinks its just a main bearing not a rod bearing but I'm just gonna change them all out while I got it apart but we will know more tomorrow night when we really get in there and check it out and no offense taken I'm the rookie hear I would rather any suggestions or advice I can get
Old 12-18-2012, 12:26 AM
  #28615
soundjunky's Avatar
Love it
so then you're looking at pulling the top end, then the piston/rod assemblies to get the rods resized.
if you've spun bearing(s), please don't waste your time/money on changing out bearings without resizing the rod.
did you do a compression test, as suggested, before you dropped your pan?
(I sure hope so)
Maybe Tjay can chime in about how to go about setting (or how much of a pita it is to set) the timing chain.
Old 12-18-2012, 12:29 AM
  #28616
soundjunky's Avatar
main bearings are only needed when things go really wrong, or the crank is pulled/resized - the rods are the first think to go - this is the way ALL engines are designed.
to pull main bearings you need to pull the transmission to drop out the crank.
Old 12-18-2012, 12:30 AM
  #28617
DiabeticKripple's Avatar
greetings from oklahoma
Old 12-18-2012, 12:47 AM
  #28618
thedude411's Avatar
***** getting technical in here. I love it.
Old 12-18-2012, 07:02 AM
  #28619
ya i dont have motor anymore, besides as stated already never swap out bearings to put used ones in....
there is a big diff in correcting someone, as to 3 people jumping down someones throat for something that was completely UNIMPORTANT!!!! besides if you didnt read it correct we were all wrong.... even at that number i believe is too high too.... the car was governed at 225.... you think about that....
besides that since when did i take offense i would just go over to all your houses and slap you around before offense was taking....
Old 12-18-2012, 10:02 AM
  #28620
https://www.cobaltss.net/forums/part...-parts-291018/
Some lsj parts if someone wants them.
Old 12-18-2012, 11:28 AM
  #28621
soundjunky's Avatar
besides that (if I would) i take offense i would just go over to all your houses and slap you around before offense was taking....
good.
I know I come off overly cereal at times, but you seem to at times take offense...
@ Will;
Technical talk is fun
@Downshift;
If you need other assistance I'm sure that Jon or myself can pop by.
PLEASE, PLEASE, PLEASE - what ever you do, don't take apart the bottom end without doing a compression test.
(you never clarified if this was done).
There's an old addage I earnestly try to stick to:
KISS
Keep
It
Simple
Stupid
If you jump to worst case scenarios (as I often have tended to do) - you can get in over your head in what could have been a realatively easy/cheap fix.
Old 12-18-2012, 11:31 AM
  #28622
soundjunky's Avatar
Can anyone tell me which side the LSJ's washer tank is on?
Mark do you still have yours?
Just wonderin out loud...
Old 12-18-2012, 11:33 AM
  #28623
soundjunky's Avatar
also, can anyone tell me if O2 sensors are covered under the (limited) powertrain warranty?
I think mine's on it's way out...
I do have a spare *somewhere*, but if I can get a new one, installed for free, I'd be all over it.
Old 12-18-2012, 11:36 AM
  #28624
pass side and will scooped it a long time ago............
i smell meth going your way, hahahaha i guess the lsj's are getting a lil to close for comfort hey...
i may have a sensor around but god knows where............ i can look for you.... jon may have one on the manifold on the spare motor...
Old 12-18-2012, 12:19 PM
  #28625
soundjunky's Avatar
meth has been in the back of my mind for a while, and it has nothing to do with competition... it's all in good fun.
If I was ever worried about an LSJ laying the smack down on me, I would have never agreed to this;
[/QUOTE]
x 100,000
Quick Reply: Calgary - random talk thread
