Calgary - random talk thread
Old 02-01-2013, 08:11 PM
  #29926
SylverSS/SC's Avatar
Oh you were receiving! Lol
Old 02-01-2013, 08:17 PM
  #29927
jrmotosports 88's Avatar
yes i sure was........ it was like a 12 worth..... dry with sand and glass dont forget the barb wire.......
Old 02-01-2013, 08:24 PM
  #29928
victoryredturbalt's Avatar
Old 02-01-2013, 08:39 PM
  #29929
EXsoccer1921's Avatar
Meh, just looks like regular grade 8 pieces to me now lol
What do you thibk makes arp studs better than stock lol. Thatsbasically all they are. Just designed to be pressed in the wheel hubs.
Old 02-01-2013, 09:07 PM
  #29930
Old 02-01-2013, 09:10 PM
  #29931
IWI Tavor TAR-21 .223 Non-Restricted
Kinda debating picking one of these up this year
Old 02-01-2013, 09:14 PM
  #29932
good !!!!!!!!!!!!!!!!!!!!!!!!!!!!
mind if i nibble on the barrel?
Old 02-01-2013, 09:22 PM
  #29933
wow. all i can say! lol
Old 02-01-2013, 09:27 PM
  #29934
hey it dont matter lol as long as it has a hair trigger and enough kick to make sure my brains hit the wall.....
Old 02-01-2013, 09:44 PM
  #29935
that decreases the value! lol
Old 02-01-2013, 11:52 PM
  #29936
DiabeticKripple's Avatar
lulz
Old 02-02-2013, 07:42 PM
  #29937
https://www.cobaltss.net/forums/prob...d-help-293042/
Old 02-02-2013, 08:50 PM
  #29938
mine did a lil something weird too when i did the thermostat..... it seems to have settled out in temps but still kinda getting warm during a pull..... i am kinda letting it settle out and see how it acts in the spring..... i knowticed a 20 degree change in iat2 at the peak of a pull.... i even had jonathan datalog and nothing seemed to be abnormal when it was analyzed..... for some reason it will slightly stumble at 6800, but seems to be perfect through out the rest of the rpm range... there a few things i want to check when i decide to to the valve cover..... i also think its a bit of a mind trick because of winter..... going from warm to cold has to muck with either the car or your own mind....
Old 02-03-2013, 11:20 AM
  #29939
thanks for the feed back brother
Last edited by victoryredturbalt; 02-03-2013 at 11:20 AM. Reason: Automerged Doublepost
Old 02-03-2013, 11:35 AM
  #29940
i mentioned it coz im wondering what thermostat did you throw in? i grabbed one from auto value.... im curious to the quality of them..... i should have grabbed a ac delco....
Old 02-03-2013, 01:15 PM
  #29941
silver_stig's Avatar
@victoryredturbalt: I tested the theory with coolant temp and the cabin heater. I played a good game of car sauna on the way back from three hills to Olds, and here are the results:
Normal Coolant temp for me: 86-88 *C
Outside Air temp: around 0 *C
20 Min of driving with Heat and fan maxed: 95 *C (rising slowly the whole time)
I turn my HVAC off: back to 86 *C
So yes, against logic, the engine runs hotter while the heater is on. Hope this helps!
Old 02-03-2013, 07:09 PM
  #29942
i grabbed one from part source.....i too may still get the one from crate engine depot as i need to order a possible maf sensor too (just waiting for unruh to get back to me on a possible test).
the stock theromstat was def ready to be replaced.
Old 02-03-2013, 07:13 PM
  #29943
Thanks!
I too went cruising from calgary to banff back to calgary. now that the coolant is mixed,
-i avg 88-90c on the highway, no heat on.
-i avg 90-92 on highway, heat on.
-i avg 92-96 idling, redlights, traffic, stop and go, heat on
my fan turns on at 92c since the trifecta tuning, drives me crazy. what is yours scheduled to turn on @? anyone else notice the temp their fan turns on @?
Old 02-03-2013, 07:14 PM
  #29944
[couple new ones from today
Old 02-04-2013, 12:22 AM
  #29945
soundjunky's Avatar
I was thinking about this earlier, and I'll mention it to Vince;
Since you've owned a TC longer than most people out there, is it possible that the tune you were running was the original one set in 2007 when the LNF was first released?
The way that GM does it is, as problems are identified, and as seen fit the 'factory' tune is updated/tweaked/changed, and when a car goes in for mechanical service tech will reflash when made aware of the need;
I didn't personally observe a change with my fan 'on' spot from stock - then again, my car was probably built a year after yours, and went in for major mechanical repairs twice, then had GMS1 flashed, all before Trifecta;
All trifecta tunes are built off the specific tune that GM says is the correct one for that car at tge time where the order is placed...
I was also wondering if a temp sensor was maybe on the fritz....
Old 02-04-2013, 02:22 AM
  #29946
car was acting up last night and all day today. think i fixed it though.
Old 02-04-2013, 02:36 PM
  #29947
ooooooooooooooooooo flat black.......................................
Old 02-04-2013, 02:57 PM
  #29948
CaptainShortbus's Avatar
Did the battery cable reset fix it for you?
Old 02-04-2013, 03:07 PM
  #29949
ooooooooooo flat white...........................
Old 02-04-2013, 03:09 PM
  #29950
Quick Reply: Calgary - random talk thread
