Calgary - random talk thread
Old 02-15-2013, 12:38 PM
  #30451
jrmotosports 88's Avatar
hmmmmm yeah its friday.................
Old 02-15-2013, 01:04 PM
  #30452
DiabeticKripple's Avatar
Mark you at the shop? I get off at noon
Old 02-15-2013, 01:56 PM
  #30453
yes i am i will be hitting the bank, but i wont be long...... i be back in 45 mins.....
Old 02-15-2013, 02:02 PM
  #30454
Ok cause it'll be like an hour and a half until I come
Old 02-15-2013, 02:34 PM
  #30455
im back already.....
Old 02-15-2013, 03:34 PM
  #30456
I'm coming now
Old 02-15-2013, 04:19 PM
  #30457
SylverSS/SC's Avatar
^ that's kinda gay
Old 02-15-2013, 04:34 PM
  #30458
Residental Bish.
Baltbitch's Avatar
You are not one to talk big boy
Old 02-15-2013, 04:54 PM
  #30459
hahahahahahaahahahahha
Old 02-15-2013, 05:59 PM
  #30460
soundjunky's Avatar
Originally Posted by DiabeticKripple
How come we get so many randoms in our thread?
yeah!!!
Get outta here you foreigners!!!
Old 02-15-2013, 06:01 PM
  #30461
soundjunky's Avatar
need some CSS to wake me up... ugg.
Old 02-15-2013, 10:14 PM
  #30462
nobody here?
Old 02-15-2013, 11:02 PM
  #30463
Hello?
Old 02-15-2013, 11:04 PM
  #30464
who are you? darn foreigners.... hahahahahahah
Old 02-16-2013, 04:03 AM
  #30465
CaptainShortbus's Avatar
Looks like ill be going with the gmpp clutch and a stock flywheel.
Exsoccer, I got that info from one of my instructors when I was going through my automotive service course at SAIT here. The way it was explained to me is that the aluminum flywheel will have less inertia at a given rpm vs the heavier steel one, allowing the engine to rev faster, higher, and in theory, make more power (much like a balance shaft delete). The opposite is that with the clutch disengaged, the heavier steel flywheel carries more energy with it vs the aluminum at x rpm, allowing more energy to be transferred to the drivetrain once the clutch is engaged. I must have overestimated the gains from going to an aluminum flywheel, from most people I've talked to, there was a noticeable increase in the ability to rev faster.
Old 02-16-2013, 04:12 AM
  #30466
silver_stig's Avatar
Hey, someone else is still up during the early hours.
Thank goodness for sait, I downloaded 100's of pages of tech info needed for my sc build.
Looks like I'll be studying wiring diagrams this weekend!
Old 02-16-2013, 04:18 AM
  #30467
I have to study for my 3rd year exam. I nearly have the hours to be a journeyman mechanic, but work has been too busy for me to get time off to write the test. Thankfully the program I took has twice as much schooling as the normal apprenticeship route, and nearly all of the extra schooling was more electrical and diagnosis classes.
Old 02-16-2013, 04:47 AM
  #30468
EXsoccer1921's Avatar
Correct. That is what i was talking about when saying the aluminum flywheel wont try and pull itself apart at higher rpms as opposed to a stock one. And as a side effect of that, you can then turn the engine at higher speeds more reliably with an aluminum flywheel than you can with a factory one. While there have been no failures to note of. I guarentee if you take a stock flywheel engine vs a balanced aluminum flywheel engine and hold them at 8000 rpms for x hours. The stock flywheel will cause crank bearing failure if not knock / slight rod "failure"(bending) much sooner than the aluminum flywheel. Because it is simply too heavy to spin that fast. Thats why engines have stock rev limiters. Has nothing to do with the powerband (like on the lnfs). It is because the engine cant safely turn beyond that rpm. An lnf can do 7500 stock just like the lsj but the ko4 cant breate past 6k so thats why they have their limit set at what 6500?
Now. About the horsepower and increase in gaining rpm speed. While on paper it makes sense and should allow you rev the engine up faster and make more power. It is HIGHLY unable to be proved. Like i said. There may be a variation in numbers on the dyno. But it is so small that even with back to back pulls on the same setup vs on with an alumin flywheel you wouldnt be able to tell a difference. Again. Even with the clutch and flywheel i have, combined with no m62 on the belt, no ac pump (stricly alternator on the belt) and not using the stock water pump and with a balance shaft delete. I feel a very, VERY slight increase in the speed at which the engine revs up.
Bottom line. Stock flywheel is good to 7500. No need to go to an aluminum unless youre going past that. I did 7500 with a stock valvetrain as well. >IF< you go with an aluminum flywheel. It needs to be balanced with the rotating assembly. Stock or not. The difference between stock flywheel and not, is hardly able to be recorded. Its like with sheding the weight of the car. Until you combine it with other things of the same benefit, you wont see a difference.
Old 02-16-2013, 05:15 AM
  #30469
Out of curiosity, why would you need the rotating assy balanced for an aluminum flywheel? Don't they just balance the crank, rods, and pistons at the factory, then balance the flywheel separately? Is it to more evenly distribute the load of the rotating assy across the main bearings? That's the only reason I can think of why you would have them all balanced together.
On a side note, just met a guy who just picked up a sunburst orange lsj a week or so ago, apparently it is pretty much maxed out on the m62. Anyways, i told him to check out gmtoc and css.net. Can't remember his name for the life of me... mark or bryan... somethibg along those lines
Old 02-16-2013, 09:45 AM
  #30470
i doubt he is maxed out but i am willing to bet it is a gmstg2.... is it a 06? it sounds like shyt i cant remember his names car..... i been here for over 5 yrs and no one has even come close to doing a full m 62 build in this town..... as matter of fact i believe i might be the only guy willing to do it.....
Old 02-16-2013, 10:05 AM
  #30471
Maybe the only guy on CSS in Calgary that's doing it. I bet there's more guys out there who aren't on here doing it! Lol just saying
Old 02-16-2013, 12:16 PM
  #30472
victoryredturbalt's Avatar
morning all happy happy sat. enjoy
Old 02-16-2013, 07:04 PM
  #30473
soundjunky's Avatar
happy saturday indeed!!!
the move when smoothly for Jamie and myself...
Old 02-16-2013, 07:14 PM
  #30474
Bah-humbug! Lol
Old 02-16-2013, 10:26 PM
  #30475
great news
Quick Reply: Calgary - random talk thread
