Calgary - random talk thread
http://www.turbobygarrett.com/turbob..._700382-12.pdf
Garrett GT3076R vs Precision 6262 vs TurboDirect GT3076R Billett 60
Here's some reading material for you kevin
We'll see
i have said my peace already. i have decided to leave that pipe right where it is then. so blue or jon, if i built a head, drop some better then avg cams in, run some meth, and drop some pistons in? would i see some gains from a 1900? hello zffffffffwat
Depends on the tune mostly. Just because you add double the amount of air being forced in doesn't mean you will go faster. You will probably blow a trans and a few clutches but you should see quite a bit more power
BRING IT!!!! I'll be waiting
i just need it to hold together for 1 night lol. hahahahhahahah
i will put a decal on it too. so that way you have something to read as your looking at it.
hows this sound? "some girls like things that stick out."
I'll get Kyle to txt it to me because I'll never be behind you
Got Bewst?
You would not. Josh is pulling numbers out of his ass with his 1900 hp estimate. And his estimated boost levels are way off. Unless you have exhaust ports the size of coke cans and mad compression I'd go with the 1320 all day. And I would never attempt pushing a 1900 without a girdled or gen 3 block.
