Calgary - random talk thread
Old 06-27-2014, 10:40 PM
  #34026
jrmotosports 88's Avatar
you know what i meat jack ass. lol im freaking tired, i accomplished fair amount today. ready for tomorrow
Old 06-28-2014, 01:39 AM
  #34027
SylverSS/SC's Avatar
oh I knew what you meant. Most poeple don't know what that means lol
Old 06-28-2014, 04:01 AM
  #34028
Got Bewst?
Bluelightning's Avatar
yes sir, getting some lovin lately. i have alot of km on the car, i needed new hubs, clutch, head gasket leak, timing was worn, the sc needed to be rebuilt, the wide band didnt work, bad exhaust build up and wasnt sucking enough oxygen. so i decided to park it for the rest of winter. i fixed it all with new hubs, new gmpp clutch, new pnp head, fresh rebuild pnp sc, head studs, ls4 tb, mongo's NBS, new timing tensioner, got a new control box for the wideband, new 3 inch exhaust and new 3 inch intake. i wanted to drop to a 2.5 and i may still but i want to wait to see what my iat2 looked like first. after that i might try a 2.6 without meth. if i finally decide to run meth then 2.5 for sure. i will have to update the tune. i may hope over to hpt from trifecta. still need to talk to some guys.
also already on the way i got some new wheels and tires. i am dropping to 17's with nitto 555 235 45 17. the wheels are lighter, anodized blue, multi spoke design with a bit of a lip. i still have to order hub adapters spacers from ebay.
if that wasnt enough i ripped the old wrap off and i still have to rewrap it. it will be a 2 tone with pearl white on the bottom and nice met blue on top. on top of that i drastically lightened my sub box. did some minor stuff like dash trims and other said ricer mods.
Awesome! Sounds like it's gonna be a good time! Don't even bother dropping to a pulley that small without meth or E. It'll just heat soak the hell out of your motor. Anything less than a 2.8" pulley on pump gas is a waste of time and very hard on a motor.
Old 06-28-2014, 06:27 AM
  #34029
yep its going to be a good time and a long day. i am already on a 2.7 with no issues of heat soaking. yep its nbs delete jon, i stand corrected. nothing like waking up at 430 in the morn to go paint up some parts.
Old 06-28-2014, 09:56 AM
  #34030
InfraRedline's Avatar
The NT555's work pretty well and last pretty long as well. I ran them on my TVS setup and was happy with them. My friend has them now on his TVS Redline and he is pleased as well. Same size too, 235/45/17.
Old 06-28-2014, 12:18 PM
  #34031
Got Bewst?
What were your current IAT's after a pull?
Old 06-28-2014, 01:58 PM
  #34032
I don't get paid enough lol
Old 06-28-2014, 05:40 PM
  #34033
after a pull they peaked at 155 on a good hot day and recovered to 125 with in a min. usual cruising temps about mid 80's on highway and anywhere in between 100/125 city.
the first time i seen the nt 555 i knew that was the tire i wanted. without having coilovers, i hope that combo looks good with hr's.
Old 06-28-2014, 06:29 PM
  #34034
Got Bewst?
Yaaaa don't pulley down without meth. You don't want temps any more than that on pump gas. But that's just my 2 cents.
Old 06-28-2014, 06:37 PM
  #34035
gotcha
Old 06-28-2014, 10:55 PM
  #34036
kevins a freaking animal hahhahahahahahaha
Old 06-29-2014, 12:23 AM
  #34037
KMO43's Avatar
Thanks Mark but like I said I've done all that stuff before and I'm there to help you get your car going tonight was fun! We'll have that clutch and shaft deletes in on Monday
Old 06-29-2014, 12:35 AM
  #34038
it was fun for sure. thx once again. time to go home back in the morn for a couple of hours for me.
Old 06-29-2014, 12:43 AM
  #34039
KMO43's Avatar
Anytime and don't worry I'll be back to put it all back together!
Old 06-29-2014, 01:02 AM
  #34040
KMO43's Avatar
Mark I know how to do the delete install now I don't know if I have taps that big and we're gonna have to find a way to do it clean it really well this should be done when the block is apart for a build
Old 06-29-2014, 01:15 AM
  #34041
i think my order with gm is getting bigger, lol. im glad im not in a huge hurry.
Old 06-29-2014, 08:52 AM
  #34042
I do have balance shafts if you want them
Old 06-29-2014, 10:58 AM
  #34043
i dont know we can talk when you get back this week right?. i do need a front cover gasket and those old guides.
Old 06-29-2014, 12:02 PM
  #34044
KMO43's Avatar
NBS or stocks?
Old 06-29-2014, 01:54 PM
  #34045
I have ottp, zzp and stock ones. Also a level zero motorsports delete kit but the sleeves need to be pressed into the block.
I shoul be back on Wednesday night
Old 06-29-2014, 02:25 PM
  #34046
KMO43's Avatar
Ya that's what Mark had said. For the deletes you have to drill holes into the block so it really should be done then have the block hot tanked to get all the drilling shards out
Old 06-29-2014, 02:31 PM
  #34047
i will make a choice on thurs when we talk. i have lots to keep me busy.
Old 06-29-2014, 03:17 PM
  #34048
He's got the stock sprockets with the balance shafts cut off
Old 06-30-2014, 11:37 AM
  #34049
KMO43's Avatar
So Mark I'm guessing we'll take today off untill Jon gets in. I'm super tired after long night leaving work early today
Old 06-30-2014, 11:46 AM
  #34050
ya no worries, i have lots to do. i got the timing front cover gasket, not bad 35 bucks. retinted the tails, painted the valve cover again. i suspect thurs will be the next day. maybe all back together by the end of the weekend.
Quick Reply: Calgary - random talk thread
