Calgary - random talk thread
Top end is stronger than the stock bottom end. When I change tuning programs, I'll spin it faster. Maybe 6500 or 7000. Gotta find stock size forged piston first
What year?
And please tell me you upgraded the 3 speed trans
There's no upgrade lol. The th400 is a drag tranny, I'd need to get a seperate computer to control a 4L80E or revert to a 700r with a manual kickdown cable
When's it gonna be done then?
They both play into being able to extend useable rev limit.
there is absolutely nothing wrong with the th400, most guys not wanting to go to a computer assisted automatic want a th400;
In years bygone I swapped one into my youngest brothers '77 Trans Am - as an upgrade from the original th350.
I have a 255 LPH pump, slightly larger injectors and an adjustable regulator. Fueling is fine. I was looking at a gear vendor overdrive unit but those are $3,500.
I can get forged cranks and rods, finding stock bore pistons is the problem
With only 4 injectors for it to be enough fuel I'm guessing the injectors will have to be at 100% duty cycle pretty much stuck open under WOT
For around 600whp at 80% IDC it'll need 141lbs or 1500cc injectors at 43.5psi
Your 80lbs are good for 535bhp at 43.5psi
If you increase the fuel pressure from what they are rated at it will improve the injector flow until you have too much pressure and then you'll be out of the pump efficiency window but only with 2 90s I think you'll be fine. I'm guessing your fuel pressure will increase 1:1 with boost so you have ~43psi at idle and 53psi at 10psi of boost?
