Calgary - random talk thread
Old 08-02-2014, 10:30 PM
  #34426
KMO43's Avatar
ATI does not recommend reving past 4500 on a completely stock motor lol
I thought it was built
Old 08-02-2014, 10:44 PM
  #34427
SylverSS/SC's Avatar
Top end is stronger than the stock bottom end. When I change tuning programs, I'll spin it faster. Maybe 6500 or 7000. Gotta find stock size forged piston first
Old 08-02-2014, 10:47 PM
  #34428
KMO43's Avatar
Stock rods? Forged crank?
Old 08-02-2014, 10:50 PM
  #34429
KMO43's Avatar
What year?
Old 08-02-2014, 10:52 PM
  #34430
KMO43's Avatar
And please tell me you upgraded the 3 speed trans
Old 08-03-2014, 12:29 AM
  #34431
There's no upgrade lol. The th400 is a drag tranny, I'd need to get a seperate computer to control a 4L80E or revert to a 700r with a manual kickdown cable
Old 08-03-2014, 12:31 AM
  #34432
They never put forged internals in any 454's
  #34433
KMO43's Avatar
So it's a 3 speed with 3.73s?
Old 08-03-2014, 12:37 AM
  #34434
Yup. The 91-93 had a 4L80E with 4.10's in the rear end. Gets about the same mileage as the 90's
Old 08-03-2014, 12:39 AM
  #34435
KMO43's Avatar
When's it gonna be done then?
Old 08-03-2014, 12:47 AM
  #34436
Put back together or pushing 20 psi?
Old 08-03-2014, 12:53 AM
  #34437
KMO43's Avatar
Well boosted
buy this: around 8:1cr
http://www.summitracing.com/int/part...make/chevrolet
Old 08-03-2014, 12:59 AM
  #34438
Won't be for a couple years
Old 08-03-2014, 01:03 AM
  #34439
KMO43's Avatar
So you are gonna run it no boost?
Old 08-03-2014, 07:02 AM
  #34440
I'm not going to turn it up past 8-10 for a while
Old 08-03-2014, 10:48 AM
  #34441
soundjunky's Avatar
this is where aftermarket balancing and align honing come into play;
They both play into being able to extend useable rev limit.
there is absolutely nothing wrong with the th400, most guys not wanting to go to a computer assisted automatic want a th400;
In years bygone I swapped one into my youngest brothers '77 Trans Am - as an upgrade from the original th350.
Old 08-03-2014, 01:49 PM
  #34442
KMO43's Avatar
I still think you'll need fueling or tuning past 10psi
Old 08-03-2014, 04:39 PM
  #34443
I have a 255 LPH pump, slightly larger injectors and an adjustable regulator. Fueling is fine. I was looking at a gear vendor overdrive unit but those are $3,500.
I can get forged cranks and rods, finding stock bore pistons is the problem
Old 08-03-2014, 04:53 PM
  #34444
KMO43's Avatar
But good enough for 20psi??
Old 08-03-2014, 05:11 PM
  #34445
KMO43's Avatar
With only 4 injectors for it to be enough fuel I'm guessing the injectors will have to be at 100% duty cycle pretty much stuck open under WOT
Old 08-03-2014, 05:16 PM
  #34446
KMO43's Avatar
For around 600whp at 80% IDC it'll need 141lbs or 1500cc injectors at 43.5psi
Old 08-03-2014, 05:21 PM
  #34447
KMO43's Avatar
Your 80lbs are good for 535bhp at 43.5psi
Old 08-03-2014, 07:05 PM
  #34448
only 2 injectors. both are about 90 lbs/hr at a certain fuel pressure. Not sure what pressure it is
Old 08-03-2014, 08:05 PM
  #34449
KMO43's Avatar
If you increase the fuel pressure from what they are rated at it will improve the injector flow until you have too much pressure and then you'll be out of the pump efficiency window but only with 2 90s I think you'll be fine. I'm guessing your fuel pressure will increase 1:1 with boost so you have ~43psi at idle and 53psi at 10psi of boost?
Old 08-03-2014, 08:55 PM
  #34450
8-13 psi at idle is stock. The tbi is good for up to 450-500 hp
Quick Reply: Calgary - random talk thread
