Calgary - random talk thread
Old 08-03-2014, 09:33 PM
  #34451
KMO43's Avatar
8-13 psi at idle is stock. The tbi is good for up to 450-500 hp
Stock or for your kit? If you have 90lbs injectors at that low of pressure and boost the pressure even 5psi it will make a huge increase in fuel flow
Old 08-03-2014, 10:41 PM
  #34452
SylverSS/SC's Avatar
That's stock. They recommend 20 psi with this kit at idle with the 1:1 increase
Old 08-03-2014, 11:14 PM
  #34453
KMO43's Avatar
Here's a good read for TBI
TBI Fueling
Old 08-03-2014, 11:59 PM
  #34454
jrmotosports 88's Avatar
time to get freaky!!!!!!!!!!!!!!!!!!!
Old 08-04-2014, 12:02 AM
  #34455
That would be the program I was looking at but now that I'm seeing the other aftermarket efi systems on boosted vehicles, I'm starting to look into those as 8 injectors are better
Having a good weekend mark?? Lol
Old 08-04-2014, 02:16 AM
  #34456
KMO43's Avatar
Ya for sure you can go anything you want with the AEM system. It's a big engine to supply with fuel under boost by just 2 injectors
Old 08-04-2014, 02:21 PM
  #34457
KMO43's Avatar
Hey Jon I'm bringing back a turbo for you!!!!
Old 08-04-2014, 05:26 PM
  #34458
You're bringing back a turbo for me?
Old 08-04-2014, 08:40 PM
  #34459
back from edmonton only destroyed 1 tire!!!!!!!!!!!!! and got a hell of a headache!!!!!!!!!!!!!
Old 08-04-2014, 09:44 PM
  #34460
?? One wheel wonder?
Old 08-04-2014, 09:52 PM
  #34461
yep I better get a new tire and roll those rear quarters as far as possible. the front is fine but the rears need more clearance. at least I only destroyed one tire and made it back safely. those roads are a nightmare.
Old 08-05-2014, 01:11 AM
  #34462
KMO43's Avatar
Yup for the 454
I don't think rolling the fenders is gonna help when your tires stick out of the body
Old 08-05-2014, 02:06 AM
  #34463
KMO43's Avatar
I also brought my V6 heads back and a pic of my truck I'll post tomorrow
Old 08-05-2014, 07:10 AM
  #34464
o believe me it will. i dont think you understand how they move when being compressed. i only hacked out 1/4 of a inch on the driver side tire. thats because i had previously pounded out the pass side a couple years ago. so the pass side was untouched. so now i need to pound out the driver side. the wheel when being compressed does not go straight up. it goes up in a angle. if it wasnt for that ridge of metal going to the inside of the car in the wheel well. the driver side would have been fine too. that ridge of metal is what i have pound up into wheel well on the pass side. thus it has remained untouched. this is why they roll quarter panels kevin. surely im not the first nor will i be the last to filling the wheel gap.
Old 08-05-2014, 08:44 AM
  #34465
If anything, I'll be doing twins on the truck later lol
Old 08-05-2014, 09:35 AM
  #34466
soundjunky's Avatar
yesterday it was warm all day, untill i nearded calgary;
iirc at our stop in brooks it was still 27, the when I turned onto (the most eastern point of) glenmore trail, it had dropped to something like 17
Old 08-05-2014, 09:42 AM
  #34467
Mark, you should just get some fender flares and bolt them on the rear. Then cut out the excess metal from the rear fenders that you don't need lol
Old 08-05-2014, 09:49 AM
  #34468
hahhahahah i will pass on that idea. now if we transplanted that procharged 454 into the balt i would do it.
Old 08-05-2014, 09:54 AM
  #34469
soundjunky's Avatar
If rolling the other quarter panel doesn't suffice, I'd wager that the adapters could be machined down a little bit...
Old 08-05-2014, 09:57 AM
  #34470
soundjunky's Avatar
yeah for 9am doctors appointments ~ which means that my 40 minute drive to work necessitates me sleeping in, and having a nice relaxing morning...
Come to think of it, this would be a sly way to semi-regularly sleep in.
Too bad I'm too honest to do that.
Old 08-05-2014, 10:10 AM
  #34471
i think at that time i would do as kevin suggested. that would be to convert to lnf axles and hubs and get them drilled for 114 bolt pattern. also run a half inch spacer on the rear.
Old 08-05-2014, 11:12 AM
  #34472
KMO43's Avatar
That'll suck becaue you just bought hubs again but now that you have power it seems to be the way to go.
Old 08-05-2014, 11:51 AM
  #34473
KMO43's Avatar
So I'm ready to race Mark...... but not in cobalts in S10s my car is still broken
Old 08-05-2014, 11:59 AM
  #34474
come on man those flames gotta give me 3000 hp. you dont stand a chance.
Old 08-05-2014, 12:04 PM
  #34475
KMO43's Avatar
Well my truck has a 4.3 in the front and a 4.3 in the back!!!! what's up now!!!!
Quick Reply: Calgary - random talk thread
