Calgary - random talk thread
Old 09-03-2014, 03:19 PM
  #35001
soundjunky's Avatar
you have already failed. i just told you the lnf and lsj clutches are the same. the gmpp clutch fits. ...
Here, a small recap;
Better have been the GMPP one! Or you failed horribly lol.
On CED I saw the LSJ setup, or the LNF setup... nothing else.
I believe the GMPP "upgrade" set for he LSJ, is essentially the LNF clutch sold for the LSJ;
Cobalt Transmissions
then again I posted;
what's a link to your GMPP clutch?
I'd wager that the clutch disc is the directly interchangeable betwen LNF & LSJ;
our output shafts are the same, but iirc it's the flywheels that are different - which may, or may not preclude a different TOB.
As my last couple posts indicated, this is what I was thinking, and why I pulled the trigger last night to try to get a replacement here asap...
In his defense, the stock clutch will handle more than most give it credit for. I think the GMPP would be a much better option, but stock will hold up well when treated right. Held up for a year and a half on Cody's old 5557 E47 setup on 430whp before 3rd gear killed itself, and a couple local E blend LNF's with pretty aggressive torque hits are holding up, granted they have been on E for less than a year. My stock LSJ clutch held up to my TVS 2.7 setup with many track launches and still looked good when I pulled it out
Thanks!
I got an email this morning from CED that the package is already on route ~ which is a heck of alot better that "at least a week out" for paying over double for hte same stuff at hte dealership next door...
Theonly GMPP clutch listed on CED's site is this one;
Ecotec LSJ Clutch Upgrade Kit 19212712
Here are two notes on the description:
This kit is capable of up to 300 hp and will give users better performance and more load capability because of increased surface area and extra clamping force.
The kit includes a heavy-duty clutch, pressure plate,throw out bearing, and bolts that are designed for easy remove and-replace service.
GMS1 is rated 290/320 on the HHR-SS which is the same as us, except for a "restriction in the intake" ~ and most of you should recall that GMS2 was in the works, and nearly released when GM hit financial troubles, and it died near release.
...and then there's this;
(*Do not use this kit for LNF vehicles)
Probably because of the wrong TOB... ???
Old 09-03-2014, 03:22 PM
  #35002
soundjunky's Avatar
Not the same clutch. Better than a LNF. Guys with high hp set ups run em without issue at all. Zrated89 used it on his last 6262 build and he said it didn't slip at all. How long it would last with 600whp tho I'm not sure lol.
assuming it's the one I mentioned last night, and then linked just a coupel moments ago, is there any hard proof that this GMPP clutch (disc at least) is different than the LNF clutch (disc)?
I see pictures often on CED that are obviously the wrong part, or used for multiple listings, so I personally won't put much weight in a generic picture.
This might all be moot, but it might be nice to know for the future.
Old 09-03-2014, 03:26 PM
  #35003
Got Bewst?
Bluelightning's Avatar
Theses no proof that it's an LNF clutch Jon. From the research ive done and read it's a clutch out of the Saab turbo car.
Old 09-03-2014, 03:28 PM
  #35004
soundjunky's Avatar
...now I think I'm going to get a french vanilla;
I forgot my second coffe at home this morning, and it's starting to catch up to me (I really need to get to bed early tonight... ugg.)
Old 09-03-2014, 03:30 PM
  #35005
soundjunky's Avatar
ok.
Thanks!
Do you know what was the Saab Turbo car was rated at?
(this might speak to the torque capacity of this clutch; we know that the LNF clutch is rated AT LEAST for 320 ft-lbs)
Old 09-03-2014, 03:31 PM
  #35006
KMO43's Avatar
I would have got the GMPP too if I was you
Old 09-03-2014, 03:50 PM
  #35007
Got Bewst?
ok.
Thanks!
Well the gmpp clutch is only rated at 300. But guys have pushed wayyy more than that out of them without issue. It's a proven clutch with a great bang for the buck. LNF guys do upgrade to them.
Old 09-03-2014, 03:58 PM
  #35008
jrmotosports 88's Avatar
does this mean your actually making a upgrade jonathan? hahahahahaha while your at it get one of those big wheel k04's. you will thank me later too, hint hint hpt time.
i maybe a lil slow but my enthusiasm makes up for it.
Old 09-03-2014, 04:12 PM
  #35009
InfraRedline's Avatar
Don't let a torque rating scare you. The stage 2 F40 clutch is rated at 310 ft/lbs, and stage 4 at 400 ft/lbs, which means mine is probably rated sub 300, and I'm shoving ~470 ft/lbs through it
Old 09-03-2014, 04:14 PM
  #35010
KMO43's Avatar
Only 470ft/lbs come on taylor step it up!!
Old 09-03-2014, 04:28 PM
  #35011
Doesn't need any more torque! haha sustained 450+tq throughout the band is enough!
Old 09-03-2014, 04:33 PM
  #35012
KMO43's Avatar
I know I'd trade some of my TQ for some more HP anyday!!
Old 09-03-2014, 04:34 PM
  #35013
thats just bad a$$
i would love to see jonathan run a big wheel. without a doubt i know it would bring a huge smile to his face every day knudge knudge hmmmmmm lil meth and some happy times ahead.
Old 09-03-2014, 04:40 PM
  #35014
KMO43's Avatar
thats just bad a$$
So you're saying he should run my setup...
Old 09-03-2014, 04:47 PM
  #35015
bingo.
i know it would make him giggle like a school girl. might even wet himself. hint hint. price is right.
Old 09-03-2014, 04:54 PM
  #35016
KMO43's Avatar
Jonathan if you do the same skip the leaking coldpipe mod. Not worth it!!
Old 09-03-2014, 05:00 PM
  #35017
KMO43's Avatar
The bigwheel is 3-4 weeks waiting list right now and i heard they may up the price.......
Old 09-03-2014, 05:12 PM
  #35018
that means if one wanted to take advantage of a good deal one should jump on it.
Old 09-03-2014, 05:16 PM
  #35019
KMO43's Avatar
It also means if you ait you'll pay more later!!
Old 09-03-2014, 05:18 PM
  #35020
KMO43's Avatar
Mark you should race him first. I'd like to see that
  #35021
it is the perfect stock like add on that will put the "BIG" in BIG BIRD.
if you did this jonathan the stars will align and the cosmos will become right. once again the slowest cobalt will be me!
Old 09-03-2014, 05:27 PM
  #35022
KMO43's Avatar
i think you guys should run to see who's faster now!
Old 09-03-2014, 05:36 PM
  #35023
your most likely right, i dont think i could take him either. o well i was trying to get him to buy one of those k04 big wheels. just some fun to be had there.
Old 09-03-2014, 05:40 PM
  #35024
KMO43's Avatar
i thought your car kicked in really good today. You ant to beat an LNF he's your guy!
Old 09-03-2014, 05:47 PM
  #35025
its so hard to tell without one beside you. i know its close but you never know for sure til you line up. if i can beat a tuned lnf it is only because i can rev til 7000 and hold 15lbs+. the big wheel changes the game.
btw kevin i may not have to go check out that room. i will call you when i know for sure.
Quick Reply: Calgary - random talk thread
