Calgary - random talk thread
Well from what little information I can gather, I think the oil pump pickup tube has fallen off the pump. It gets little spurts of oil when accelerating and shows normal oil pressure for a few seconds. While braking, it shows no oil pressure.
It's either that or the screen is plugged but that seems unlikely given the symptoms. The oil pump could be pooched. Guess I'm jacking the motor up and pulling the pan to see what I got going on in there
moroso makes pickups that bolt to one of the 4 bolts on the pump so it can't fall off. After my pickup fell off and my engine blew I bough the moroso pickup great upgrade
Mark wanna load your tune today?
GM and the tool manufacturers must be in together to really **** people off. I need a universal to get 1 oil pan bolt off and my set doesn't have any. So I'm 1 bolt away from seeing if I have to jack the motor up to get the pan out.
On the plus side, I figured I might as well put the new deeper tranny pan that I bought in and since the inspection cover is off, my hi torque starter is going in
Don't you go to work soon? So you have to wait to fix it
Take out the distributor and check the oil pump driveshaft and if you hook it up to a drill you can run the pump and see if it works
take off a valve cover and watch the oil at the rockers
I could hear the roller rockers chatter when oil pressure was at 0 and the chatter would go away when the oil pressure surged for a few seconds
