Calgary - random talk thread
Got Bewst?
got the money? i dont lol @ kevin
to be fair to that guy, even if we got clean runs win or loose, its just not enough. im not even sure a tvs would cure what i want. i think i just want a better car or truck in the first place. something i can start fresh with, and have much more potential.
maybe its my mid life crisis time hahahahahahaahaha
Sorry to break up the love fest..... I don't recommend doing anything under a vehicle in a garage without a lift! It's a bit of a workout for the upper body and the vocabulary
And for those of you not on Facebook......
Last edited by SylverSS/SC; 09-15-2014 at 05:11 PM. Reason: Stupid ducking autocorrect
dude you know me, i will always work somewhat close to my means. it takes time to compile parts and build a car. the biggest issue would be to get anything decent out of the balt. no sense in giving it away. in the mean time i will keep my eyes open for a tvs.
So are we doing meth for this weekend?
Aaron is still trying to come down too!
Boo
Happy?
And driving into the car wash the other day, I could still see the 454 outline on the box in the water vapor
wanna see rematches with meth!!
i think if we got a clean run off i would have nosed him. the only reason is because i rev to 7200. i never got past 5500/6000 in third. we both know thats where my car is happiest.
meth would allow me to pull on him. so if your looking for a really close race it is his car and mine as they sit.
Not running at least to the top of 3rd is a no good race in an LSJ! Not saying you'd beat him for sure, but you need to have a fighting chance.
Jon, how do you even get traction in that truck?!
@jon
that will always be there forever and ever so get use to it lol. you wont see the outline as per say, but with water vapor and static thats a different story. you need a new box anyways hahahahaha. bloody miracle the truck looks as good as it does.
No I want to see you win!! But will be a good one to film and post!
DO METH!!
Should be able to wet sand it out
DO METH!!
Apparently the gas isn't a switch anymore. It's now a adjustable dimmer.
Guess who was lounging around in the bottom of the oil pan not doing what they were supposed to be doing??
there is no need to wet sand it. you can if you want but that wont cure static. or the way water sits on the area. you cant see hardly anything as it sits dry and clean. when a decal has been on a area for extended periods of time it will some how always attract dust or water vapor and you will see a ghosting. you dont see the scratches. even if you did i could use heavier compound.
that part is a slacker and should be fired.
So I'm talking to Paul the guy with the STG1 he's coming by on fri and we're gonna put some work in!
Hey Jon too bad you can't data log with HPT you could setup the chart to show how fast you can drain your tank on WOT!
So Mark it's on for Sat Paul and Sean are coming and Aaron prob too!
So this should be a good learning experience. Gotta pull the oil pump to install the screen and pick up. They are a press/hammer fit so I would suspect that the stock pump and tube got put in when my motor was rebuilt 3 years ago. I'd say it either came loose on install or was installed back in to the pump. So looks like I may be installing a new pump if the tube doesn't go back into the hole and fit tight
Got my coldpipe just waiting on ced now
That's what everyone and even the melling video I watched said to do. I just outta get some 2x4's an I'll be set to get that rodeo under way
Got Bewst?
Mark your waffling is exactly why I gave up my Balt. I loved it. Had it setup really nice towards end but I wanted a rwd platform that I could modify to the enth degree. That's when my 89 was started. Not that it's any cheaper. I'm 45k into this one and probably looking at 550 ish at wheels if I give it all the 100-150 shot. Now after I supercharge it over winter I'm hoping for 650 to wheels. But I'm also debating switching out to a ls or 512.
